Sedan Chat Thread
Old Dec 15, 2014 | 11:08 PM
  #5251
AroundTheG37's Avatar
AroundTheG37
Originally Posted by Mik3G37S
Damn, until now, I've never noticed that, now I see what you're talking about and you sir are definitely right about this, that being said, the companies providing the springs for our cars, should've thought about this and compensate for it having the front springs drop a bit lower
This.
Springs are added for performance but also because of looks and companies need to factor that in when making their product. I'm pretty sure no one here would be complaining if the roles were reversed (rear higher than front) but it is what it is.
I will say this though, the swift springs are definitely an improvement performance wise over stock and I'm happy with the camber after the drop. Almost enough to not give a damn about the discrepancy.
Old Dec 15, 2014 | 11:10 PM
  #5252
G37Xtreme's Avatar
G37Xtreme
Originally Posted by Yadayada
The profile pic of Rochester's car shows exactly what I'm talking about. Look how much higher the front fender is cut than the rear. It's making it seem higher than it really is. I'm not denying that it has more of a gap than the rear, however it's not all due to the fact of an uneven drop. Some of that is due to a higher cut fender.
I just measured my stock fender height front and rear, and the rear was 28.5" and front was 28" off the ground.
Granted, my driveway slopes away from the house, and I back in, so the front is downhill.
Do you think a measurement on level ground will show the rear as lower?
I guess I can pull straight in tomorrow and see how that affects things too.
Also, the front bumper is lower to the ground than the rear, so that will add illusion making the front look deeper (well it is deeper, because there's more material in the front)
Old Dec 15, 2014 | 11:36 PM
  #5253
AroundTheG37
Oh man, things are getting interesting.
I just measured floor to fender on both and my fronts came in at 26.5 and my rears at 26.75.
Old Dec 15, 2014 | 11:49 PM
  #5254
RexHavoc's Avatar
RexHavoc
Right, that's what I was trying to say earlier. My car is perfectly level and visually I'm way lower in the rear than the front. To match up the drop visually, which I think the swifts do for the X sedans there has to be a slight rake to the car.
When I readjust my coils I'll be going for a visual level based on fender gap not an actual level of the body of the car.
If that makes sense.
Old Dec 15, 2014 | 11:52 PM
  #5255
Yadayada's Avatar
Yadayada
I am intrigued to know what the measurements are on a level ground! Maybe tomorrow I can even find level ground and measure and report back to compare..
It's quite interesting isn't it?
We still need to meet up and compare drops Todd. Im done with finals on Wednesday.
Old Dec 16, 2014 | 12:06 AM
  #5256
ChinkyChoy's Avatar
ChinkyChoy
I was going to say measure your fender heights to double check things out.
Some of you guys are almost as low as me and I m on coils....
Old Dec 16, 2014 | 12:20 AM
  #5257
AroundTheG37
What coils?
Old Dec 16, 2014 | 05:21 AM
  #5258
LOL
Old Dec 16, 2014 | 07:03 AM
  #5259
Lego_Maniac's Avatar
Lego_Maniac
That's it. Exactly what I see when I look at my car today... 6MT, swifts, 15mm spacers and duckfeet. I think I was telling you earlier that it's not perfectly 100% flush. It's more, um, normal looking, if that makes sense. IDK what "perfect" would be for that configuration. A few extra millimeters on both, but not exactly the same front to back.
Just like the assessment on RWD Swift Springs: there's a lot more that's good here, much more so than there is not-quite-right, so it's a win.
Yeah, I don't know what the exact configuration would be, probably larger in the front. IDK how people run 20mm in the rear. 16 or 17mm spacers in the front would probably be "perfect" but I'm really happy at how this turned out.
While we are on the subject of gap, my dimensions are below. I'm running a little less than 1" difference front to rear. I should measure again now that they have settled.....
I wonder if the 370Z shocks have anything to do with it
Attached Thumbnails Sedan Chat Thread-afterfront.jpg   Sedan Chat Thread-afterrear.jpg
Old Dec 16, 2014 | 09:05 AM
  #5260
ChinkyChoy's Avatar
ChinkyChoy
What coils?
dropped on BCs my fender height is 26" all around
Old Dec 16, 2014 | 04:46 PM
  #5261
That's exactly how I set my coils too, zero gap and 26", easy for daily driving but still has a nice low stance.
Old Dec 18, 2014 | 09:55 AM
  #5262
Car is in the shop today. Mechanic is re-installing the support bar that connected the OEM cats to the frame... with some creative welding to the FI cats.
Or at least, that's the plan, knock on wood. No pics because it's a drop-off. Sorry guys.
Just realized that I haven't driven the car in 5 days. Wow, that's kind of lame.
Old Dec 18, 2014 | 10:01 AM
  #5263
G37Xtreme's Avatar
G37Xtreme
Any withdrawal symptoms yet?
Old Dec 18, 2014 | 10:13 AM
  #5264
No man, I just got a quick hit of car awesomeness just driving to the mechanic, rush hour notwithstanding.
Besides, snow tires, and Winter in general... kind of puts a damper on everything.
Old Dec 18, 2014 | 02:21 PM
  #5265
twin_snails's Avatar
twin_snails
Yep should of went Eibach
Sacs, what is the drop on the Eibach's versus the swifts? We're talking the pro kit yes? Is the drop more even between Front/Rear?
