Sedan Chat Thread
Of course there's no point in rotating an evenly worn set of tires side to side, unless maybe you drive a UPS truck. Because they lay out their route to take as many right-turns as possible. Because traffic.
As for one sidewall always being on the outside... outside is outside. Do you know of a different definition for "outside" that I'm not privy to?
Now you're just trolling. LOL If you're like this with tires, I can only imagine having a political discussion. Hoo boy!
Also, BB knows whats up too.
They have an asymmetrical tread design. Not the same as directional, but the inside shoulder of the tire has a different rubber compound and tread design than the outer shoulder. Therefore they need to be mounted a certain way on the wheel, not position on the car or direction of travel. I don't remember where I saw it, but I did read the the PSS have a soft compound on the outer shoulder for awesome cornering grip and a harder more durable compound on the inner shoulder to help them last longer.
http://www.tirerack.com/tires/tirete...jsp?techid=180
This is quite the hilarious discussion. If the asymmetrical tire is mounted properly (with the lettering that clearly says "outside" is mounted on the "out" side of the wheel) you can do a full 4 wheel rotation. Only exception is if you have a directional set of wheels that wouldn't look right if they were mounted on the wrong side of the car, or a staggered setup, (but you could still side to side rotate in that case).
But continue on....................
Ahh, rather than reflect on your incorrect statement you resort to ridicule just like you always seemingly do. It's the tell-tell sign of someone who is defeated so I'll just say thank you and move on.
The funny thing is, like Tony said, we are 85% in agreement.
I'm getting my clutch bleed on Saturday. The default fluid is ATE amber, although I can pay additional for something else.
I have 2 unopened bottles of Motul RBF 600 that I'm thinking about bringing to see if they will use.
Thoughts or suggestions?
^ I remember reading that the RBF600 absorbs water molecules out of the air very quickly. Since the clutch isn't something you bleed as often as the brakes it might not be a good idea to use RBF600 for the clutch.
I'm using Motul 5.1 for my clutch since I hope to track the car a lot, but the plan is to change it out quite often.
If I had a dollar for every time you pretend to win an argument that exists solely in your head, or think that your ridiculous declarations about "defeat" before moving on (LOL) mean anything to anyone... well, I'd probably only have enough to buy lunch. But even then you'd still be whining that I owe you money, god knows why.
Or you could simply man up and admit you got confused about asymmetrical tires. It's not the end of the world. Your head won't explode.
I use RBF in all my cars for brake fluid, but I also bleed my brakes pretty frequently.
Considering there is speculation fresh fluid can prolong the life of the csc, and that a local Z shop wants $40 to bleed the clutch, maybe I'll just start doing it annually
I've read the same thing about RBF 600, but never saw any actual data that validates that claim.
Seems some people recommend ATE Super Blue for mainly street use.
LOL, ironic coming from you but since you went there, I'm inclined to use this gif.
http://media.giphy.com/media/KpnNFksPmWwyk/giphy.gif
The reason I posted this gif is because if I'm wrong, why not be tactful about it instead of being a douche? Ever heard the phrase you catch more flies with honey.........? Then maybe you wouldn't get butt hurt (and me likewise) when I come back at you. However, I am right (we actually both are so it's a moot point) and I was trying to be nice in proving this to you but you once again got all high and mighty. It really doesn't bother me because I enjoy this type of banter but I'm sure the mods frown upon it so let's say we cut the chit? However, we average one of these a month so it's to be expected?
So we both agree that asymmetrical tires can not be swapped because they have an inside and outside. So, why did you say this?
Can we confirm if there are in fact DIRECTIONAL ASYMMETRIC tires out there? And then...are any of them in use here on this forum? Those would be the only people who can't rotate at all...unless it's a square setup, which would allow a front to back rotation.
Once again, you won an argument with yourself. Well done, buddy.
