Sedan Chat Thread
TreadDepot.com: Toyo Proxes T1 Sport Tires
If you call them ask for Andrew and mention myG37.com hopefully shipping won't be brutal.
I'll second this. I had the S04's on the stock 18's and loved them. I've got PSS on my 19's now (only 800 miles or so), and I can't say that they're that much better. I'll give it a few hundred more miles to be sure.
and that tire screech at the end wasn't 2-3 shift, it was actually 3-2 downshift
Toyo T1 Sports and they have them in those sizes
Considering how many mods you've done in the last year, the parts that you used, and the cumulative cost for all that, plus shipping to PR, plus installation; and suddenly you're complaining about a few hundred dollars as the reason to compromise on the tires you really want? The tires!?!
When you put it into context like that...
I think I will regret if I don't go with the Michelin PSS. My main concern is how long will these tires last with my driving style (mostly granny driving with moderate hard accelerations).
Staggered sizes have a 15,000 mile warranty, so you should be able to get at least that out of them.
Yeah..idk. The Michelin PSS besides having a great reputation are also by far the lightest tire @ 24 lbs for the 245/45/18 and 27 lbs for the 275/40/18.
The PSS also has a good reputation for tread wear; vastly better than the RE050A, which rip up in 10K+ miles.
And finally, with regard to your concern for how long they last... see my previous comment and put that in proper context, too. But if you're still worried about it, then move to a square setup so that you can rotate front to back. That's actually pretty good advice, right there.
Alfredo, I realize that everyone's story is different, and I've long ago stopped trying to put myself in your shoes, because quite frankly, it doesn't make any sense to me. I don't get you, man. So I gave that up, because it's none of my business, and with exception to actual friendships made here, it's usually best to focus on the cars, not the forum member. But (!) we are all defined with the values established by our actions, and in the last year you've dumped thousands of dollars into bolt-on mods (and a tune). Recently you were talking about some high-end lightweight 18" wheels, even lighter than the Enkie RPF1. Seems to me if you're going to spend $2000 - $3000 on lightweight wheels, a few hundred added dollars in tires isn't even a blip on the radar.
/oldmanrant
Do any of you guys have a noise coming from the fuel tank (under the car by the hoses/heat shield) that sounds like a constant hiss/whine that sputters a bit? Infiniti says they see nothing wrong with it but it doesn't sound that normal to me.
Also, had a q50 loaner and I have to say, I love the steering wheel they put in there. I wonder if we can swap it in?
You are correct about the PSS being light-weight. At 24 pounds, they are a full 3 and 4 pounds lighter front to rear respectively, compared to the OEM Bridgestone RE050A. That's pretty amazing, IMO. I suspect that if you put the OEM-sized PSS on a lightweight wheel like the 18" Enkie RPF1, you'd be loving the change.
/oldmanrant
/oldmanrant
I actually did order those wheels, so I'm just going to go with the Michelin PSS for now and see how long they last and if I like them enough to get another set after they get worn out.
Thanks for the old man rant and advice.
You're welcome, Alfredo. I can only imagine how psyched you're going to be with those light-weight 18's and PSS. You might get the lightweight-bug and buy yourself a new drive-shaft, too.
Sounds good enough. That's about a year and a half for me.
I understand your point completely. I'm more concerned about the tires than my past mods, because tires get worn out and need to be replaced and I don't want to be spending $1250 on tires (plus mounting and balancing) every year and a half.
Some better questions, with more of a bite to them:
- Do you routinely launch the car as hard as you can out of the hole? The reasons are immaterial... for the fun of it, street racing, drug smuggling.
- Do you normally hear the tires screech when you pile into a turn?
- How many times a day do you curse out loud and say, "Goddamn Understeer!"?
- When you come to a highway ramp, is it a game to see if you can take it at twice the posted speed?
This is just off the top of my head. I'm sure other people can come up with similar questions.
Kettle Black? Mr. Pay attention to all his mods and how much they cost.
Yeah, but now you could be digging too deep. The reality is most people never drive their cars anywhere near the limits of the what their tires can actually do. For instance, if someone just does the occasional highway pull, stoplight drag, or indy turn, then maybe they will happy with a s04, v12, etc. type tire. However, this does not mean I condone people throwing on chit tires like nexen, etc. just because they drive like a grandma. I just think it can vary from one person to another but by all means continue the probing. I think it would be interesting to see how my fellow sedan enthusiasts driving patterns are.
