Sedan Chat Thread
Old May 1, 2014 | 02:10 PM
  #2461
From what I've seen, the best bang for buck are long tube headers with resonated test pipes, stillen gen3, and catback of choice (2.5" or better and a decent sized resonator). Then tune it...330whp+ on a good day.
Actual long tube headers have no cats; i.e. no test-pipes. There's no room, because of the long-tube header design.
Unless you're thinking of simple aftermarket headers (like Stillen), which are replacements for our OEM shorties.
Old May 1, 2014 | 02:28 PM
  #2462
Lego_Maniac's Avatar
Lego_Maniac
I ordered one of MTECs shifter springs. Only found one review and it was on a G35 with STS so not really a good comparison.
Figured it was easy to install and I want to change out the transmission fluid anyway when I put on the exhaust so ill be on the area. At $32.98 I don't have much to lose.
Old May 2, 2014 | 03:27 PM
  #2463
Never heard of this. What are you expecting, Lego... will this pull the shifter handle to center faster than otherwise?
About 30 years ago, I had a Hurst shifter in an old T/A, and that thing snapped to center so fast and firm. Is that what this is all about?
Old May 2, 2014 | 04:46 PM
  #2464
Lego_Maniac
Its supposed to reduce side-to-slide slop. Basically there is a spring on each side of the transmission behind a 27mm bolt. These are stiffer springs. Im not expecting much, but if i could reduce the side-to-side play I would be happy.
The BRZ and Si crowd seems to have positive reviews on it.
Ill already have my car up on ramps to do the exhaust and trans fluid, this wont add much time or cost to the process. I never thought changing out the clutch return spring would make such a difference either. Consider me a guinea pig
Old May 3, 2014 | 05:39 PM
  #2465
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Today was productive. I cleaned my throttle bodies (which at 60k miles didn't seem to need it), washed my car, and removed the hood liner. I will say that I was surprised at how much louder the intakes sound without the hood liner. The weight savings alone should add at least 5hp. Now to finish cleaning up the spray wax that was tipped over in my trunk during the spirited drive after all of today's projects.
Old May 3, 2014 | 05:49 PM
  #2466
Originally Posted by '11G37S
... and removed the hood liner. I will say that I was surprised at how much louder the intakes sound without the hood liner
Another convert to going commando. Welcome to the club.
Old May 3, 2014 | 05:58 PM
  #2467
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Well all of the cool kids were doing it so naturally I had to do it too.
Old May 3, 2014 | 07:59 PM
  #2468
RexHavoc's Avatar
RexHavoc
Wanna come and wash mine too? I just got home today and am whupped.
I wonder if your TBs had been cleaned before? Mine weren't too bad but they definitely needed to be cleaned.
Had some very spirited driving of my own, I drove Skyline Drive yesterday and while I was very well behaved in the park there were plenty of twisties getting back to the highway. Of course the Smoky Mountains were a blast and found plenty of folks to play with to make the hours pass. My left arm is cooked however.
Old May 3, 2014 | 08:30 PM
  #2469
warped ideas's Avatar
warped ideas
A quarter past stripped
Washed, polished and waxed the G today.... Then it poured on me while cruising down town Fort Lauderdale. Looks like it hasn't been washed in weeks. Damnit
Old May 3, 2014 | 08:33 PM
  #2470
warped ideas
Will removing the hood liner affect the hoods paint at all with there being less insulation from the heat? I'm intrigued..... more noise!
Old May 3, 2014 | 08:47 PM
  #2471
connoisseurr's Avatar
connoisseurr
Absolutely not. Your hood gets hotter from the sun hitting it during your hottest months of the year. The insulation is mostly for noise I thought. Could be wrong
Old May 3, 2014 | 08:51 PM
  #2472
It's for sound deadening. There's no liner on the 370Z.
If you don't like it off, you can always put it back on.
Old May 3, 2014 | 08:55 PM
  #2473
RPG11's Avatar
RPG11
Taking mine off tomorrow might post some pictures
Old May 3, 2014 | 09:22 PM
  #2474
RexHavoc's Avatar
RexHavoc
Nah but the damn paint on the hood.... My paint isn't the best, I get that. But after the road trip my front end is ALL beat to snot. Going to need to give it a scrub and break out the touch up paint. I'm starting to seriously consider wrapping the damn thing.
Old May 3, 2014 | 09:29 PM
  #2475
I read it on the g35 page if i'm not mistaken. is better if i'm wrong cause i took it off
So which is it... You're removing it tomorrow, or you just took it off? These posts were 17 minutes apart.
