G37X Sedan Speed-sensitive Steering
Old Aug 16, 2009 | 10:34 PM
classy37's Avatar
classy37
The G has this option, but has anyone noticed a change in steering feel between parking lot and highway speeds? I barely notice any, if at all- steering feels the same at 5mph as it does at 75mph. Not a huge deal as I love the handling, but I thought that the speed-sensitive steering would give a much softer feel at very low speeds.
Then again maybe this is something that needs to be broken in? I have <2K miles.
Old Aug 17, 2009 | 12:14 AM
Mike S.'s Avatar
Mike S.
Doubt the break in period. I think at parking lot speeds it easy to turn, but at highway speeds it firms up nicely...its not dramatic, but steering is not soft while moving at a good clip.
Old Aug 17, 2009 | 12:16 AM
classy37's Avatar
classy37
That's the thing - I'm not finding this. Just as firm as at highway speeds.
Old Aug 17, 2009 | 12:40 PM
RISKY GUY's Avatar
RISKY GUY
power assisted. turning is the SAME, its just how much effort is needed at higher speeds.
Old Aug 17, 2009 | 12:43 PM
Alex57r's Avatar
Alex57r
I don't think its supposed to be dramatic.
Old Aug 17, 2009 | 12:53 PM
classy37's Avatar
classy37
I've driven the following cars that have this feature and the effect is pretty dramatic. You almost turn the wheel with one finger below 10mph-
2006/2007 M35X
2006 VW Passat
Maybe this is a different feature?
Old Aug 17, 2009 | 01:12 PM
da mayor's Avatar
da mayor
its the amount of rotation you have to turn the steering wheel that makes it the speed sensitive
Old Aug 17, 2009 | 05:41 PM
mindonmatter's Avatar
mindonmatter
In other words.....
It doesn't change the force required to move the steering wheel, it changes the actual steering ratio.
Old Aug 17, 2009 | 10:38 PM
Mockenrue's Avatar
Mockenrue
You notice it more when you don't have it. I used to drive an 06 Acura TSX, which had great stiff handling on the road, but gave your arms a real workout in the parking lot.
Old Aug 18, 2009 | 11:46 AM
classy37's Avatar
classy37
Originally Posted by mindonmatter
In other words.....
Makes sense.
What is the feature that I am describing called? The M35/X definitely has this (very soft and easy steering below ~15mph, much firmer as speed increases).
Old Aug 18, 2009 | 03:52 PM
fromSVXtoSTi's Avatar
fromSVXtoSTi
2 systems
Originally Posted by classy37
Makes sense.
There is speed sensitive power steering. This changes the hydraulic assist based upon vehicle speed. This is standard on the G. It is intended to do what you described...make low speed steering effort lighter while maintaining good weight at higher speeds for a stable feel.
There is also 4 wheel active steer which is an option, but not on the G37x. This is the system that actually changes the steering ratio so that you don't have to input as much steering angle to do tight maneuvers at low speed.
I think you're talking about the 1st one. It may feel heavy at low speed, but I can guarantee you it's lighter than it would be without the assist!
m3clubracer
Sep 11, 2016 09:01 PM
drewfinity
Sep 8, 2015 09:10 PM
mauiwowie
Aug 16, 2015 06:01 PM
zero260
Aug 12, 2015 10:02 AM
