Compatibility: Swapping Non-4WAS Steering Rack into a 4WAS G37 Coupe?
Old May 25, 2026 | 02:51 AM
Q370's Avatar
Q370
Hi everyone,
I’m currently drifting a G37 Coupe equipped with 4WAS. I already have the 4WAS fuse pulled/cut to bypass the system for drifting.
Recently, my steering rack started leaking oil and needs to be replaced. When looking for a remanufactured rack, I noticed that only the Non-4WAS versions are available in stock. Since my 4WAS is already disabled, I am considering swapping in the Non-4WAS rack, but I want to make sure it will bolt up and function without mechanical issues.
For reference, the part numbers I found are:
  • With 4WAS: 49200-JK02A (or B)
  • Without 4WAS (Standard): 49200-JK00A (or B)
Since this is a dedicated drift car, I don't care about the dash lights being on (the Christmas tree is already there). However, I am worried about the steering angle sensor or speed-sensitive steering system messing up the steering center/alignment after the swap.
Has anyone successfully done this swap or know if it's a direct bolt-on mechanically? Any advice on steering center issues or potential pitfalls would be greatly appreciated!
Thanks in advance!
for gemini translate JP to EN
Old May 25, 2026 | 09:59 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Have you read through this thread that forum member @BULL put together? BULL also has/ had a 4WAS car so if the answer you are looking for isn't in that thread perhaps you can shoot him a PM. I know he is busy with IRL stuff but he does his best to reply forthwith.
That said, the way I understand the 4WAS system, the front rack should have no direct effect on the rear assembly. The steering angle sensor (SAS) is part of the steering column so the rear gets all the information it needs from there, not the front rack. BULL will correct me if I am wrong...
Good luck.
Old Yesterday | 10:46 PM
Q370's Avatar
Q370
I couldn't find the thread.
Thanks for posting the link!
blackandwhite
Apr 19, 2024 02:08 PM
infamous84
Sep 10, 2019 05:30 PM
MossySpoon
MODDING 411
Oct 4, 2015 10:34 PM
mauiwowie
Aug 16, 2015 06:01 PM
porcupine
Nov 30, 2007 11:25 PM
