Would rear camber arms alone be enough for a 1” drop?
Old May 9, 2023 | 07:14 PM
kk4635's Avatar
kk4635
Is this all I would need for a minimal-1” drop? I just want to fix the wheel gap my car has at an affordable rate. I’ve heard lowering the car can create camber issues, so are the rear camber arms enough to combat this for a small drop?
Old May 10, 2023 | 03:52 PM
kk4635's Avatar
kk4635
What suspension components are needed for a 1" Drop?
Lowering my car by 1" this weekend on Tein Flex Z coilovers. I bought rear camber arms and toe bolts as that seems to be what gets far off when you lower our cars. On a 1" drop, will this be okay or will I end up needing the front camber setup as well?
Old May 14, 2023 | 07:34 AM
zoe infinity's Avatar
zoe infinity
do you plan doing it by yourself ?
Old May 14, 2023 | 08:35 AM
goldbug's Avatar
goldbug
You’ll be fine with just rear camber arms and toe bolts at an inch or less of a drop 👍 Same setup here. I’m lower than that on the Flex Z coilovers in my coupe too and still haven’t “needed” front aftermarket upper control arms/camber arms, with a fender gap of a finger or two. IIRC I’m at -2.1 or -2.2 degrees of camber in the front- caster and toe was the limiting factor IIRC, since you can’t adjust the OEM upper control arms caster and camber, and only have so much toe adjustment up front on OEM arms.
Half of a good alignment is finding a shop with someone who knows how to use the alignment rack properly- I was lucky I had a friend at the time (before I started wrenching on Volvos) heavy into suspension work who fine tuned everything for me. If you have a shop locally that you’ve seen lowered cars at, there’s probably someone there who knows how to jam on a Hunter rack and get you setup in spec- might be worth asking around unless you already have a shop you trust.
Enjoy the coilovers! Makes it a different car.
Old Feb 21, 2024 | 11:10 PM
coupebc's Avatar
coupebc
Reviving this thread to see if anyone has ever tested this with G37/370z... but
Would pulling out some negative camber in the rear also pull in the added toe-out from lowering?
I'm wondering if it would really be necessary to get toe bolts because my alignment shop did get toe within spec but on the high side. I'm not sure if its the added camber affecting toe or just the geometry change of lowering overall.
Currently at an aesthetic but overly aggressive -2.4 camber in the rear and about 0.15 degrees toe out and would want to maybe -1.5 camber.
Old Feb 28, 2024 | 12:12 AM
digital.aaron's Avatar
digital.aaron
Toe and camber arm eccentric bolt lockouts are pretty standard gear for lowered Gs. How much are you lowered? And is this RWD or AWD?
Old Feb 29, 2024 | 07:35 PM
coupebc's Avatar
coupebc
1.2" front 0.9" rear give or take a bit, this is the out of the box setup on my HKS coil overs
Old Mar 6, 2024 | 10:01 PM
digital.aaron
You're probably right on the cusp of needing some adjustable arms. What did your alignment shop say?
Old Mar 7, 2024 | 09:05 PM
coupebc's Avatar
coupebc
Just said they didn't want to try too hard to get everything perfect because the adjustments were a bit crusty, didn't wanna break anything. they actually got the toe back into spec but better to be close to zero for street use.
Dtyler
Aug 25, 2022 02:37 AM
Steezus_g37
Jun 4, 2015 08:59 AM
leanlikeacello
May 14, 2014 05:15 PM
boelee
Oct 18, 2013 11:58 PM
dvsgp6
Jan 10, 2013 05:46 PM
