Are rear stock camber arms adjustable?
Old May 14, 2014 | 03:18 PM
leanlikeacello's Avatar
leanlikeacello
I recently lowered my car and my rear camber is uneven. The driver side is -3.1 and the passenger side is -2.7. I was wondering if it's possible to adjust the passenger side more negative so it can be more even? Thanks.
Old May 14, 2014 | 03:20 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Holy crap! 3 degrees of negative camber!
The rear of the car has some adjustability for camber, but it maxes out if you drop the car beyond around an inch.
Put a camber kit on there to bring it back in to spec and not wreck your tires. How low are you?
Old May 14, 2014 | 03:22 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
This information has been discussed thoroughly on the forum. There is minimal adjustment on the rear and none on the front. You will not be able to get anywhere in the ballpark of OEM specs starting where you are at. You need a camber kit.
Old May 14, 2014 | 03:30 PM
leanlikeacello
I just want to adjust the passenger side from -2.7 to -3.0 is that possible?
Old May 14, 2014 | 03:35 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
Yes, if you buy rear camber arms that are adjustable.
GoFightNguyen
Because Racecar
Wat.
You want *more* negative camber? It'll max out both ways. It all depends where you're at. If you want more negative camber, then yes, you can probably camber it out more. Similarly, a camber kit can push it - shudder - *more* out of spec.
I hope you realize you are going to be rapidly chewing up your tires by running them like this.
Old May 14, 2014 | 03:50 PM
leanlikeacello
Wat.
Im lowered and im running wide wheels so i can't run oem spec camber. i was just wondering if i could even out the camber without buying aftermarket camber arms
Old May 14, 2014 | 05:15 PM
Ryne's Avatar
Ryne
Honestly, at this point it doesn't matter. You are wayyyyyyy out of spec anyways. You aren't going to gain anything by evening out the camber. The handling and tire wear are going to be equally as compromised as they are now. I don't even think you would really be able to notice the difference of 0.4 degrees camber by the naked eye so you won't gain anything aesthetically either.
Ipp391
Aug 28, 2015 09:27 AM
Jensen Mathew
Aug 16, 2015 08:06 PM
Redfire32
Aug 11, 2015 09:05 AM
