Q60 Final Teaser - Revealed in Detroit
Old Sep 7, 2016 | 12:20 AM
  #3061
tomcatm's Avatar
tomcatm
Originally Posted by Ape Factory
I'm waiting patiently for my local dealer to get a 300hp 3.0T test driver in but it'll have to be a Sport which you can't even configure on the Infiniti web site yet. I think it'll be six months before I can test drive an RS and I'm not a first year kind of guy.
You should just head to Houston, the dealership next to my house has 5 or 6 300hp models on the lot and they are definitely letting people test drive it.
Old Sep 7, 2016 | 01:37 AM
  #3062
ThebigJ's Avatar
ThebigJ
Although I am not satisfied about the new q60 I have to say I disagree with the criticism about the HP of the new 3.0TT.
First of all this is not something new, BMW has a very similar engine with the same output since 7-8 years. A direct injection twinscroll (Infiniti has advantage here with TT) 3.0 turbo which is used in models ending 35, and let me tell you 335 feels MUCH faster than my g37.
I believe most people here know that HP itself is meaningless, what matters is the torque curve. 300hp may seem low but its max torque starts from 1500RPM which means unlike the 3.7 VQ engine that only gives its peak torque at really high rpms with the new engine you are almost always in the max torque band. Even with the 7at you can not always keep your rpms very close to the max hp rpm therefore 3.0TT will be considerably faster than the outgoing model no doubt!!!
Now the problem is, almost every company uses a similar approach and have turbo v4 and turbo v6 with similar output so infiniti is not standing out in that department...
I wish Q60 was considerably lighter and the entry 2.0 liter turbo came with 275hp or so like most of the 2liter turbos today(wrx,camaro, 310 in 2.3 ecoboost, bmw328 is probably also close but underrated), and than instead of a RS I wish all 3.0TT's came with 370hp.
I don't like RS version since it is just more horsepower with no improvement in handling and too expensive.
Old Sep 7, 2016 | 08:20 AM
  #3063
Landshark's Avatar
Landshark
... and I'm not a first year kind of guy.
same here - learned my lesson.
its going to need Android Auto (because if i can't swap a head unit, i better at least be able to configure it how i like it, features and sound-wise)
i will also have to try the climate control, because i HATE what's in the G37.
Old Sep 7, 2016 | 10:56 AM
  #3064
eljoker's Avatar
eljoker
Here is another Dyno on the Red Sport Q50 . This one is from Fast Intention's and I post this because someone said that the didn't trust stillens. Well here is another shop with similar results. Now unless they are using the same dyno, the VR engine is showing under rated from factory.
Now it looks like with some Intakes and a tune, 400+ whp is possible.
Attached Thumbnails Q60 Final Teaser - Revealed in Detroit-screenshot_20160907-095322.png
Old Sep 7, 2016 | 01:41 PM
  #3065
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I agree that the engine is a beast.. just please no run flats on the Q60 RS400. When I test drove the Q50 RS, I felt like I was losing 1/2 second from standing acceleration because I couldnt hook up quick enough. Summer tires and an extra 10 or 20 mms in width FTW
Old Sep 7, 2016 | 01:51 PM
  #3066
tomcatm's Avatar
tomcatm
The spec sheet posted earlier shows RWD RS models get conventional summer tires, while AWD RS models get runflat all season tires. SS models get Run flats for both RWD (summer kind) and AWD (A/S). Only the RWD RS gets the staggered set up with wider rears.
So I remember downloading the U.S. Q60 owners manual 3 weeks ago and under the Tires and Wheels section it was still showing 20in wheels with 275 width tires. I just downloaded a new version and the first thing it says is that the info in the Tires and Wheels section has been updated - sure enough, they have taken out the 20in wheels. It just shows 19s across the board with RS having 245/265 set up. There also seems to be a 245 and a 255 option for the front and rear also (guessing SS models get 255s all around). And in the manual they seem to RFs across the board. More confusion....
Old Sep 7, 2016 | 02:24 PM
  #3067
gill1606's Avatar
gill1606
Here is another Dyno on the Red Sport Q50 . This one is from Fast Intention's and I post this because someone said that the didn't trust stillens. Well here is another shop with similar results. Now unless they are using the same dyno, the VR engine is showing under rated from factory. Now it looks like with some Intakes and a tune, 400+ whp is possible.
Wow just look at those numbers creeping upwards with relatively simple mods
Old Sep 7, 2016 | 02:51 PM
  #3068
04gtoryder's Avatar
04gtoryder
I wish someone would post SAE numbers somewhere. All I see are STD which can vary greatly based on location and tend to run high. My old GTO dyno'd 425whp STD and 400whp SAE same day same run.
Old Sep 7, 2016 | 02:54 PM
  #3069
eljoker's Avatar
eljoker
Im hoping with Down pipes, CBE, Intake, and a 93 octane tune it can hit 450whp. Thats asking for a lot I know but I an dream right? Also I saw a thread where an RS Q50 took an SRT8 300 with bolt ons. Im not to familiar with the STR8s but I was an older Gen.
Seems promising. Now we just need some one to offer transmission services as I still think that needs some work.
Old Sep 7, 2016 | 07:26 PM
  #3070
P Casey's Avatar
P Casey
It's going to depend on where the restrictions are. If Infiniti left nothing to gain, then you're going to be getting just a bit extra. The 435 and a few of the new model Turbo'd are like that, with the exception of the more expensive ones such as m4 GTR RS, etc.
SRT 300 is a boat and does a 1/4 in like 13.4 and lucky to hit 0-60 in under 5 seconds. Unless you're on spray.
Old Sep 7, 2016 | 07:34 PM
  #3071
P Casey's Avatar
P Casey
Watch for all the upgraded turbos within two years.
Old Sep 7, 2016 | 08:06 PM
  #3072
Landshark's Avatar
Landshark
will the transmission be able to handle that in your dream?
i had it out with an SRT8 Charger in my Subaru Legacy (around 290hp) - the Charger could not pull on me, we were neck and neck. sad how their massive heft kills any performance from that giant engine.
Old Sep 7, 2016 | 08:32 PM
  #3073
eljoker's Avatar
eljoker
I think it will but I also put that I wish someone would work on transmission upgrades. Still done believe that the motors are underrated?
Old Sep 7, 2016 | 09:53 PM
  #3074
Ape Factory's Avatar
Ape Factory
Exactly.
Old Sep 7, 2016 | 10:17 PM
  #3075
Landshark's Avatar
Landshark
never said i didnt - underrating by 10-20hp ... sure.
underrating by 50-75hp is a missed opportunity and bad marketing (unless you are trying to get over on some regulation, but thats not the case here).
