Transmission coolant line question
Old Feb 1, 2020 | 08:01 PM
Flakman's Avatar
Flakman
So I've been having some coolant leakage at the rear of the engine. It seems that it's coming from the transmission coolant lines behind the engine, just above the center plate. What is odd is that about 6 inches of one of the coolant lines (probably the one leaking) is rubber, while the other is completely solid tubing. Is this how it should be or did someone do a "repair" at some point?
Thanks,
John
Old Feb 2, 2020 | 01:11 AM
Kpmikey808's Avatar
Kpmikey808
Check ur heater hose connector - my car 57k miles & that plastic piece just cracked - it gets brittle & old
& will leak from there
Old Feb 2, 2020 | 12:32 PM
slartibartfast's Avatar
slartibartfast
Just as manufacturers use flex-pipes in the exhaust to deal with engine movement during throttle changes, they use rubber hoses in various lines that go from moveable parts to static parts. While the radiator is mounted on rubber pads, that's to prevent vibration fatigue, not to handle motor and transmission movement. Someone will chime in shortly who has fiddled with these lines and can answer your question.
Old Feb 2, 2020 | 02:40 PM
Flakman's Avatar
Flakman
Thanks, though this is leaking behind the engine, so unlikely to be the heater hose.
Old Feb 2, 2020 | 02:43 PM
Flakman's Avatar
Flakman
Understood. Just seemed strange to have only one with a hose between. Looked at the FSM and it doesn't look like there should be a hose there. I may just see if I can find a replacement hose to fit and use worm gear hose clamps.
Old Feb 2, 2020 | 04:16 PM
Flakman's Avatar
Flakman
Okay, I'm an idiot. The hose definitely looks OEM and goes from the pipe end to the coolant manifold on the transmission. It has very specific bends in it so off to find a part number.
Old Feb 2, 2020 | 05:19 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Any chance you can post a picture of the failed hose? If this is something other than the infamous heater core hose/coupling, then it is another object of potential concern. TIA!
Old Feb 3, 2020 | 09:26 PM
Flakman's Avatar
Flakman
Yeah. I'll get a pic going. Maybe the P/N can be identified as well.
Thanks
Old Feb 9, 2020 | 09:45 PM
Flakman's Avatar
Flakman
Pics
Hope everyone had an awesome weekend.
I apologize for the delay. Lots going on. Here are some pics of the hose. It attaches to the upper coolant port on the transmission. The lower is a pipe, not a hose. Hope this helps. If anyone could get a P/N that would be awesome. I've looked through infinitipartsonline and others and everything shows a pipe direct to the tranny.
Thank you.
Old Feb 9, 2020 | 11:57 PM
antirice's Avatar
antirice
If you have a coolant leak behind the engine, one possible source could be below:
Old Feb 14, 2020 | 12:00 AM
Flakman's Avatar
Flakman
I don't think that's it. On my transmission cooler manifold, both input and output are about 2" apart. Looks like yours are quite a bit apart. I'm going to look closer at the routing on that and see if it matches the turns on my hose.
Imtiaz Yousuf
Jul 28, 2018 09:53 AM
steven92
Sep 18, 2015 12:04 AM
FlState
Jan 17, 2013 04:33 PM
shinekpk
General Tech Questions
Dec 12, 2011 12:43 AM
