Service engine light - gas cap?
Old May 26, 2019 | 11:06 PM
kaii's Avatar
kaii
so like about last month the ses light came on and i had an oil change done and the guy said there was too much oil? but i check the dip stick before and it was perfectly fine.
and the light went away after the oil change and today when i turned the car on the light is back on.
i changed my oil filter and air filters that same day also.
i have a 2011 g37 sedan btw.
alright so the code was something with the fuel cap any fix?
Old May 26, 2019 | 11:10 PM
PNW_IPL's Avatar
PNW_IPL
Gonna need that code read bruh. Report back when you have it. Nobody is going to know anything until that code is read.
Old May 26, 2019 | 11:11 PM
kaii's Avatar
kaii
Kk ill take it tmr, idk to me i think its something w the oil i have no clue
Old May 26, 2019 | 11:12 PM
PNW_IPL's Avatar
PNW_IPL
Shouldn't be connected but it's possible it triggered something else.
Old May 26, 2019 | 11:14 PM
Bommerang's Avatar
Bommerang
Yeah man you gotta pull the code and see what is reads for us to help you!
Old May 27, 2019 | 12:36 AM
kaii's Avatar
kaii
yo my friend came over and got the code and its something with the fuel cap, i had an alert about the fuel cap being loose before but it went away. any fix
Old May 27, 2019 | 05:27 PM
Bommerang's Avatar
Bommerang
If its the code for the fuel cap being off then,
Either you drove around with your fuel cap loose/off and it popped the code which should go away after sometime when you tighten the cap.
Or if indeed your fuel cap isnt sealing properly or something odd youll just need a new one.
Old May 27, 2019 | 05:42 PM
kaii's Avatar
kaii
i had a loose fuel cap alert come up once before and i got out of the car and removed it and put it back on and it wasnt loose. then about a month later the first ses light came on, so im guessing i should just replace it
MagicPinstripes
Jan 10, 2025 02:25 PM
SteveG37
Feb 9, 2008 02:32 AM
Nick-L
Jan 6, 2008 09:13 AM
TunedG37
Nov 13, 2007 09:22 PM
mal_TX
Oct 11, 2007 11:59 AM
