Upper radiator hose replacement
Old 02-17-2019, 08:09 PM
Infin88
Infin88's Avatar
Hey guys, my upper radiator hose is leaking. I got both hoses replaced maybe less than 10k miles ago (2 years ago) and I believe either the hose is bad or the connection to the radiator is cracked. The leak, which is located where the upper hose connects to the radiator, started when it got cold here in the northeast.
I would prefer to not get a new radiator ( i mean if thats the only option then i guess ill do it). Im going to first try a new worm clamp but if that doesnt work my question is
-can i remove the upper radiator hose without having to drain the system?
-is there a better (material) hose to use other than oem that may fix the issue?
-any other suggesttions?
thanks
Old 02-17-2019, 11:58 PM
JSolo
Just say no!!!!!
JSolo's Avatar
It's been a while since I've look at hoses in the car. You could siphon enough from the filler neck to drop the level below the radiator upper hose fitting. You may have to stick the siphon tube deep into the hose to reach towards the radiator. Check existing clamps? Are they still snug? Might just be a matter of tightening up.
I don't see why you can't remove the hose without draining the whole system. If you do end up opening the system, you will need to ensure there's no air in it using a burp funnel or vacuum filling.
Infin88 (02-18-2019)
Old 02-18-2019, 09:15 AM
Baadnewsburr
Baadnewsburr's Avatar
Silicon hoses are a popular replacement and they tend to last very long
Old 02-18-2019, 10:35 AM
Infin88
Infin88's Avatar
Yeah im worried that over tightening the clamps could break that piece if the radiator.
i may try silicone hoses...i think they sell them at z1
Old 09-19-2020, 11:50 AM
Brad Empson
Brad Empson's Avatar
Did you ever fix it?
I have a leak in the same location and replaced the hose but it still leaks.
Old 09-19-2020, 12:25 PM
Infin88
Infin88's Avatar
So i actually just replaced the clamp with a typical worm clamp (that you screw to tighten) Seemed to have fixed the leak on my end. Are you still using oem clamp?
Nehro
05-22-2017 07:00 AM
saywat?
04-18-2017 03:01 PM
Lou@Amplified
Engine/Intake/Exhaust
14
04-02-2013 10:32 PM
6MT-G
General Tech Questions
03-29-2013 11:48 PM
NeverBoneStock
04-12-2012 11:25 PM
Quick Reply: Upper radiator hose replacement
