Won't shift completely into park
Old Oct 7, 2016 | 04:27 PM
RichardMiami's Avatar
RichardMiami
They adjusted the shift cable - no charge under warranty.
I had some other work done, and we had a hurricane in between, so it took a week.
Old May 3, 2020 | 05:13 PM
Luciajohns's Avatar
Luciajohns
I have a similar problem. I have a 2009 infinity g37 and the car runs fine but when I **** the car off it won’t register that it’s in park j have to manually pull up my shifter a bit for it to stop beeping otherwise I can’t lock the car when I get out of it. I just got a bran new battery so it can’t be a battery problem. Not really sure what to do
Old May 3, 2020 | 06:05 PM
Conboss's Avatar
Conboss
If you pull the pin up and it stops, try lubricating the pin. It may not be fully releasing.
Old Mar 8, 2021 | 07:06 PM
vqRob07's Avatar
vqRob07
Originally Posted by macdog1997
still no luck. the white pin that goes into the shifter seems to be working correctly. It locks into park and won't let me go into reverse. but still indicates the light on gauge cluster, and constant beeping.
IDK if you fixed it or not but im having the same problem and its becasuse my car was broken into and they broke the shifter off and broke 2 pins which i see you are also missing this is the problem and lmk if you saw it by now an how you fixed it
joey2965
12
Aug 24, 2017 02:35 PM
rolltidealumni
Feb 17, 2016 01:33 PM
Age
Aug 18, 2009 04:34 PM
g37mobbin
MODDING 411
Jun 5, 2009 11:45 AM
ironchef2008
Nov 6, 2008 09:29 PM
