MyG37
MyG37 (https://www.myg37.com/forums/)
-   Engine, Drivetrain & Forced-Induction (https://www.myg37.com/forums/engine-drivetrain-and-forced-induction-309/)
-   -   Won't shift completely into park (https://www.myg37.com/forums/engine-drivetrain-and-forced-induction/278287-wont-shift-completely-into-park.html)
macdog1997 Sep 8, 2016 01:19 PM
2008 automatic G37s coupe. Car will shift into park, however when you turn the car off, it states on the display to shift P (saying it's not in park) any help?
2011-G Sep 8, 2016 02:26 PM
Not trying to be funny but you can always try disconnecting the battery and then connecting it back on.. Mite reset the error?
macdog1997 Sep 8, 2016 03:12 PM
Yes I've tried that. Not to sure what could be causing this. I've done as much research as I can on it.
2011-G Sep 8, 2016 03:20 PM
Not sure what's causing this but there is a pin underneath the gearbox that clicks when you change gears - Maybe that is broken? not too sure about this but guessing right now
I'm sure someone can help you in time. Good luck
macdog1997 Sep 8, 2016 10:36 PM
thanks. The car is rebuilt. but in great shape. got her for $7700 and this is the only issue I've came across.
Kris9884 Sep 9, 2016 10:05 AM
Yeah its just gotta be a sensor or something not catching while you put it in park. Should be fairly simple but no idea where it is, sorry..
macdog1997 Sep 9, 2016 01:11 PM
I figured it's gonna end up being something small. I've been playing with it. replaced the shift lock relay. still no luck.
macdog1997 Sep 12, 2016 06:15 PM
Bump. someone help me out lol
maGorheadrush Sep 12, 2016 11:03 PM
I have this happen all the time. There's a pin that gets stuck under the shifter. If you have an aftermarket shift knob it may be on too tight. If its stock that white pin may just be getting stuck in a less than full released position. Try taking the knob off and lubricating. This always seems to work for me. Really frustrating issue though
macdog1997 Sep 12, 2016 11:49 PM
2 Attachment(s)
still no luck. the white pin that goes into the shifter seems to be working correctly. It locks into park and won't let me go into reverse. but still indicates the light on gauge cluster, and constant beeping.
maGorheadrush Sep 13, 2016 12:22 AM
Have you tried pulling up on the white pin? Mine will engage in park even if the pun isn't all the way up
macdog1997 Sep 13, 2016 03:05 AM
I'll try that today. is there a how to, on taking off that interior plastic surrounding the shifter? I'd like to get underneath it to further diagnose if this isn't the problem.
macdog1997 Sep 19, 2016 02:17 AM
bump still no idea whats going on.
maGorheadrush Sep 19, 2016 07:30 AM
Have you read this?
https://www.myg37.com/forums/g37-cou...in-park-2.html
Last few posts hopefully will give you some additional ideas..
RichardMiami Oct 1, 2016 02:40 PM
This happened to me this morning... 2013 G37 Sedan. I drove it to the dealership and let them worry about it - the car is under full warranty anyway.
I will post here when I get an explanation.
© 2026 MH Sub I, LLC dba Internet Brands
