Timing chain gasket blown, need help with part info
Old Nov 18, 2015 | 10:12 AM
  #76
Bocian's Avatar
Bocian
Yea this issue has been blown a little out of proportion but in a way rightfully so due to it being a costly repair that is essentially infiniti's fault. However the chances of this happening are still rather slim. Like BB said, it's very counterproductive worrying about it, but knowing about it helps deal with iT.
So im over this hurdle as well as the csc failure hope that's all of the defects because I really enjoy this car and wouldn't want to change it. I got it at a great price, plus I was sideswiped and had money left over from the insurance after it was fixed and the gaskets and csc ended up costing about 1300$ in total so in the grand scheme of things, I think I'm still ahead and I have the known issues done and over with.
Anyone know of any other major issues like this that I should be aware of? I'm even scared to ask...
Old Nov 19, 2015 | 06:39 PM
  #77
Here's my gauge install and happy to see healthy oil pressure at all rpms
Old Nov 19, 2015 | 10:58 PM
  #78
Bocian's Avatar
Bocian
Nice work, hope it stays healthy
Old Nov 20, 2015 | 09:37 AM
  #79
nelledge's Avatar
nelledge
n00b
Nice install. Must be a relief to find the oil pressure is normal the first time that gauge lights up.
Two questions:
  1. Is your floor mat on your accelerator pedal?
  2. Why does your clutch pedal look so funny, is that custom?
Old Nov 20, 2015 | 10:00 AM
  #80
m3clubracer's Avatar
m3clubracer
It's a hybrid high performance on/off clutch. In between a manual and a sequential.
Old Nov 20, 2015 | 01:58 PM
  #81
Lol, u guys
Might have to recheck that mat as I may have covered that pedal a bit, didn't rev high so I suppose it's ok but nice catch!
Old Feb 3, 2016 | 09:28 PM
  #82
dmg6768's Avatar
dmg6768
Sorry to resurrect an old thread, but I bought my g used with 77k miles. It's got 86k now.
I had my local infiniti dealer fax me the service records and found this. Does it look like they replaced the internal gaskets too, or do you think they just replaced the gaskets for the outer cover?
Do you think its possible I could get the dealership that did this service to fax or email me an itemized invoice with all the work performed?
thanks!!
Attached Thumbnails Timing chain gasket blown, need help with part info-untitle.jpg
Old Feb 3, 2016 | 10:12 PM
  #83
thanks!!
It says the rear cover was resealed, so you should be good to go as that would be all the internal seals that are affected by that bad timing gasket.
Old Feb 3, 2016 | 11:28 PM
  #84
dmg6768's Avatar
dmg6768
Thank you for the info, man.
Old Feb 4, 2016 | 09:58 AM
  #85
Bocian's Avatar
Bocian
Yup you're definitely good, the dealer replaces the entire rear cover which includes the two gaskets that go bad so you won't encounter this problem since you had that done, I'm sure you'll sleep a bit better now
Old Feb 4, 2016 | 10:16 AM
  #86
IracknBack's Avatar
IracknBack
Can anyone share what the lowest miles ever reported for this issue to occur? I have an 09 Sedan 6MT that I just bought with 44k miles. I'm a pessimist so would like to expect worst case scenario.
Old Feb 4, 2016 | 10:40 AM
  #87
As little as 18K on some VQ engines. Some that are older and have over 100K have never experienced the issue. There's no predicting if or when it will occur.
Old Nov 29, 2021 | 07:26 PM
  #88
adrianbf's Avatar
adrianbf
Sorry for reviving this thread but I'd like to fact check some things. I ordered the parts from infinitipartsdeal.com and they just recently sent me an email saying that the gallery gaskets (13533-JK21B & 13533-JK21A) and the camshaft oil seals (13042-3HD0A) are not compatible with my car per its VIN number. I have a 2008 Journey coupe. Does anyone know why they would not be compatible? AFAIK all these parts should be good between the 2008-2012 range.
TheDevilsG
43
Mar 19, 2021 01:30 PM
Tommy Gunz PSIU
29
Feb 5, 2020 10:24 PM
Apr 13, 2019 05:34 AM
G37sTimCA
Feb 24, 2019 01:46 AM
haveyoumetcp
Jun 8, 2017 04:25 PM
