2008 G37S coupe timing chain replacement
Old Jan 22, 2013 | 05:20 AM
Glenn2008's Avatar
Glenn2008
I just purchased a 2008 coupe and when I asked what service I should expect at 100K, the dealer said I will need to replace the belt. I checked online and found that this car has a timing chain. Does it have to be replaced at 100K?
Old Jan 22, 2013 | 05:52 AM
G37Sam's Avatar
G37Sam
Nope, the timing chain is not serviceable and theoretically designed to last "forever".
Old Jan 22, 2013 | 08:10 AM
Modme's Avatar
Modme
They probably meant the serpentine belt. Like Sam said, timing chain does not need replacement.
Old Jan 22, 2013 | 08:12 AM
Glenn2008's Avatar
Glenn2008
Thanks guys for the info. I'm used to Honda's that have to be changed at 100K. Looks like the G37 engine has a very limited maintenance schedule.
Old Feb 5, 2013 | 05:06 PM
1scG37s's Avatar
1scG37s
Generally the Drive belt will be changed around 110k?.. (please correct me if im wrong), and the t-chain does get a look over with possible tightening, and reseals of the grommets and gaskets for the timing belt cover.
sLADe781
32
Nov 28, 2015 03:23 AM
Slateg37
Sep 16, 2015 05:52 PM
GW330
Aug 12, 2015 12:19 AM
reigle9
Aug 6, 2015 02:45 PM
JakeG37
Aug 2, 2015 12:00 PM
