Help 2008 LCD display
Old Aug 8, 2015 | 01:17 AM
GW330's Avatar
GW330
2008 LCD display
My 2008 G37 NON-NAV display is starting too fade/die. Before buying a used one from an '08, will the updated one from '11 (non-nav) fit/work with the 2008 radio? Has this been done before? Based on photos ive seen the plugs look the same.
Thanks in advance!
Old Aug 8, 2015 | 09:51 AM
Enrique95's Avatar
Enrique95
2008 LCD display
Subscribed for answers too
Old Aug 8, 2015 | 02:08 PM
ILM-NC G37S's Avatar
ILM-NC G37S
LCD screens from 2010+ models will NOT work on the 2008's and 2009's. The newer screens use a different interface and would require swapping out the entire AV controller (radio). I wanted to swap out the screen in my '08 because the newer ones have better resolution but unless you're willing to swap out the whole system you'll have to stick with a '08 or '09 model.
Old Aug 12, 2015 | 12:19 AM
GW330's Avatar
GW330
Thank you, wanted to do the same while replacing the failing display.
vamarris
Dec 9, 2018 11:10 AM
Stevolkz33
May 28, 2016 02:36 AM
Jdragon1974
Sep 29, 2015 09:15 PM
m3clubracer
Sep 28, 2015 03:45 PM
