G37 7speed transmission reprogram
Old Jul 2, 2012 | 07:05 PM
  #1606
Marc Collins's Avatar
Marc Collins
Originally Posted by 2009G37Bandit
OK, now back to 7 Speed Transmissions. I JUST got my 2009 G37 Sedan Back an hour ago from the Dealer and had the 7-Speed Re-Program performed (Along with the 2011-2012 Navigation Update I purchased for $99 and the dealer charged me $109 to install ).
To refresh your memory, since this posts is super LONG, I was given a 2012 LOANER CAR. It was nice, BUT Shifted VERY SMOOTH shifting and didn't FEEL as fast or fun to drive as my 2009 (For sure!). I noticed this right away. Now also it's important to note, I've had this car 4 weeks, so not a lot of drive time on her yet.
were very smooth, the 1-2 shift was like Butter. To be honest, my initial impression was that I LIKED the 2009 BETTER Before.
It was behaving just like my 2012 Loaner car I had for a day and a half. Probabaly has the same program????????? Again, this was a short drive home 930 miles) and my G still had power, BUT, the overall charateristics of the transmission just seemed much more refined and not near as AGGRESSIVE!
My 30 minutes drive so far hasn't blew my socks off. Again, I still wanted it because I wanted the latest and greatest and read many good reviews, but the MAIN THING I feel, is it is smoother and NOT as AGGRESSIVE. It downshifted hard before and threw me back in my seat. It still goes fast, but just feels more Like a Cadilac than the Car I just had been driving the last 4 weeks. Maybe it gets better, but that is my QUICK INITIAL impressions. Anyone else agree?
If you read back in the thread, I make reference to those who want a Lexus-like experience. They are the majority apparently, so the new programming is designed to keep them happy.
What you need to do is spend some time in DS--and see if it offers the sportiness of the old "D" mode. If so, we have the best of both worlds. If not, we just have "neutered" as others have described.
Old Jul 2, 2012 | 07:58 PM
  #1607
joselitopr's Avatar
joselitopr
I have my car tune.Should i get the tune remove and back to stock before take it to the dealer. To my under stand the tune would be erase with the dealer up date.
Old Jul 3, 2012 | 03:16 PM
  #1608
Marc Collins
PLEASE!!!!!!!!!!!!!:
Those who have had ITB12-27 or ITB 12-27a applied, please stick your car in DS and drive a while and tell us the following comparisons to the prior DS mode:
1) Does the tranny still rev-match and downshift on panic (very hard and/or sudden) braking? (Removed from the new D apparently)
2) Does the tranny still largely ignore M mode shift requests and refuse to upshift below 2,000 rpm and downshift aggressively when slowing or braking (instead of acting like Manual mode should and waiting for a shift command unless you come to a complete stop and forget to downshift)?
3) Does the tranny still fairly aggressively downshift on coasting to a stop? The original D mode did this, but it has been removed or severely softened from all updates to D, including this latest one. Some say it has also been softened in DS. It is designed to mimic a manual transmission, so for people only used to automatics, it might actually feel like the brake is being applied (fairly gently) upon coasting. Does that still happen in DS?
4) After you stab the throttle or brake and "set off" the performance mode in DS, how long does it remain in "pounce mode" under normal driving before it calms down awaiting the next sharp input? The old DS was over-responsive in some applications...staying on high alert for several minutes after a five-second "incident" of high performance. If the new one responds quickly and appropriately in the first place, there is no need for it to act like a scalded cat when you just want to drive along normally.
Answers to these 4 questions, hopefully with some consensus, will be very helpful. Thanks!
Old Jul 3, 2012 | 03:35 PM
  #1609
TinsleyC's Avatar
TinsleyC
?.. even filled with Premium Gas and cleaned spots off it.
really... Sewell in Dallas never asks loanees to fill them, they do that for you. But they do use the Regular pump located behind their used car lot.
Old Jul 3, 2012 | 04:18 PM
  #1610
Track Bandit's Avatar
Track Bandit
Well Marc here goes. I currently have a 2012 G37S 7AT Coupe:
1.Yes it still rev-matches in the DS mode.
2.Yes, it takes over control of the tranny in certain situations. Often downshifting for you if you're braking hard, and sometimes upshifting if you're nearing the redline or holding a high rev. point, all while in the "M" mode.
3.Yes, it rev matches in certain gears while breaking in DS mode such as 4-3 and 3-2. I don't mind this.
4. Yes, and then almost as quick as it started it disappears. When I need the throttle to respond quickly with a little pedal movement, sometimes it's there, sometimes it's not. I never really know.
I don't know why this should be such a problem for Infiniti. Doesn't the M35 have a nice little switch near the seat warmers which allows you to switch from "Eco, Sport, Normal" modes? It sets up the engine, tranny and suspension parameters for the car so they know how to do this, it's just they've only put in on the M series of cars. Kind of stupid I think since the G series sedan and coupe are a better match for this and the market they are going for. JMO
Al
Old Jul 3, 2012 | 05:31 PM
  #1611
Damn Dirty Ape's Avatar
Damn Dirty Ape
Well, I called and spoke with the service manager and casually mentioned I had been digging around and tossed this TSB 12-027 at him. He called me back later and told me I did indeed have the most current update for my year, model type. He said if there was a newer update than I have they would be happy to try to solve my lag problems by applying it. Said they simply cannot since the system shows nothing newer.
Car is 2011 G37xS Sedan 7 A/T.
Well damnit.
Old Jul 3, 2012 | 07:08 PM
  #1612
Dexter_Morgan's Avatar
Dexter_Morgan
I took my 2009 G37x in today and they said they could not find any codes and that my ECU flash's are current. I asked about ITB12027 and they said I had that applied in Jan. Go figure. Anyway they want to keep it through Thursday, do some more testing and maybe take them on a ride to demo lag & hes. sucks
Old Jul 3, 2012 | 08:17 PM
  #1613
JimK157's Avatar
JimK157
I was told by my service manager that they cannot tell if a tsb applies to a vehicle until they attach their programming tool to the ecm. They said if it did not apply they could tell me quickly otherwise they would apply it. When they finished they said ITB 12-027A was applied. A year earlier I had the ITB 10-75 applied and it really did not make much of a difference.
For everyone with 2009 thru 2011's I can't see how they are up to date when this tsb came out in May 2012. In the case of my dealership I don't think they have done too many of these to date.
Old Jul 3, 2012 | 08:55 PM
  #1614
scotty_g's Avatar
scotty_g
Long term followup to the update: I received the update a few weeks ago. I posted right after I got it. Car def is better. Again I don't think it's totally fixed but pretty dam close. Everything is smoother now. Some may not like that. The engine was very edgy before if you know what I mean. I have a 2011x sedan and they update it now problem. Bring a printout of the service update if you have to. This came out in May and is brand new! I recommend it for all who qualify. You should be happy overall.
-Scott
Old Jul 3, 2012 | 08:58 PM
  #1615
CougarRed's Avatar
CougarRed
What?
Here's the main differences for me in D mode:
1. I feel I have more throttle response/torque at lower RPMs in lower gears
2. Reduced lag accelerating after braking/coasting or after cornering
3. A lot less engine braking when coasting to a stop with the foot off the gas
About the only thing that would qualify as Lexus-like is #3.
Old Jul 3, 2012 | 09:01 PM
  #1616
rburt's Avatar
rburt
@Dexter_Morgan, see post 1246 in this thread. It says that if they aren't using a current version of the Consult software, it won't list any available updates. Hoping that helps.
Old Jul 3, 2012 | 11:31 PM
  #1617
Marc Collins
Originally Posted by CougarRed
What?
Yes, you are correct. For those who had interim updates with lag, it is desirable to get rid of it. For those of us who bought an Infiniti instead of a Lexus on purpose, #3 is an unfortunate inclusion in the fix of other problems. #3 is just a choice that Infiniti has decided to go mainstream instead of sport sedan.
Old Jul 3, 2012 | 11:33 PM
  #1618
Marc Collins
Al
Thanks for the great info. Only missed one. #3 is downshifting moderately aggressively while coasting, not braking. Does DS mode still do that (the original D on mine does as well)?
And I completely agree with you re: the M switch. The next gen G better have that!
Old Jul 3, 2012 | 11:38 PM
  #1619
mikeb2004's Avatar
mikeb2004
Yes, absolutely, in DS it does.
In D it also downshifts but it is subtle and not noticeably rev matched.
Yes, and yes.
In D, yes today I noticed especially going down hills and coasting, it downshifts nicely, not aggressive but you get some decent engine braking. I like this, it's not over the top, just good behavior from D mode. I didnt go down the SAME exact hill in DS, to compare, but my experience with DS is that "it is more aggressive with the downshifts and very noticeably rev-matches them". DS is a lot of fun now, without being absurd like before.
Yes D will stay in pounce mode for a reasonable amount of time. I don't know what everyone's ideal time is. And the car of course can't know what the road ahead looks like. It does a nice job, IMO. In DS it stays on "high alert" for longer. I know what you mean about the old behavior... DS use to stay in that mode for much too long. Now it seems more reasonable but definitely longer than in D.
Old Jul 4, 2012 | 11:11 AM
  #1620
2009G37Bandit's Avatar
2009G37Bandit
Update, My Tranny feels better now. I just replaced 17" stock wheels with 19" OEM Coupe Wheels and 19" Micelin Super Sports, feels like a totally different car. The shifts seemed to hold much longer (higher RPM), but I asked a few and they said no reprogramming for TIRES were needed, so maybe the car just feels different with these tires on it, but I like it better now than I did 2 days ago!
I have a 2009 just FYI
