G37 7speed transmission reprogram
Old Jun 26, 2012 | 10:45 PM
  #1546
DJ JMARx87's Avatar
DJ JMARx87
Originally Posted by trcb777
Getting my done right now at Infiniti of Gwinette. Will report back. Service dept here is awesome. I have intake and exhaust and did not say a word except sounds awesome.
i went to get an oil change when the tsb was realeased last friday. they said it wasnt out yet. I will be calling this week for an apointment.DOMO
Old Jun 26, 2012 | 10:52 PM
  #1547
CougarRed's Avatar
CougarRed
Originally Posted by CougarRed
Got my 2010 Sedan done today.
Agree with the statements above: The car’s personality with this update is totally different. On my way home, I noticed I'm driving a different car. Much more responsive.
3 weeks later - still loving the change.
Old Jun 26, 2012 | 11:05 PM
  #1548
Silver37's Avatar
Silver37
Judson is his name. Dan Dienhart was the service consultant. I told Dan the problem with the trans was harsh down shifts and lag in higher gears.
Also talked to Judson and he was the one who told me they have had complaints about the trans lag and they have a new reprogram that there going to install and has received good feedback from the update. I also had the TSB sitting in the passenger seat just in case. I also got my oil changed for 1/2 off
Thank you...I'll give him a call and see if we can line it up.
Old Jun 27, 2012 | 07:18 AM
  #1549
Chris11LE's Avatar
Chris11LE
Originally Posted by hobbs
Anyone compared mileage before and after? The only thing I notice on my 2012 purchased 6/11 is a rare harsh downshift from 2nd to 1st when coming to a stop. Has happened maybe 5-0 times in the last year. It always seems in the right gear when turning a corner, the only thing is it could be more responsive at 60-70mph on the freeway. I do not want to make it worse.
I could swear Im seeing a good increase in MPG BUT it needs to be taken with a grain of salt, since I was rarely driving in D before the flash so I could get around the laginess.
Now I havent even touched DS or the paddles in almost 2 weeks, D seems to be performing well enough that I dont feel the need to. If calculations are correct Im looking at 20 or 30 miles more than normal before Ill have to fill up. My car normally gets 18mpg or so, so 20-30 extra per tank is 1 or 1.5 gallons of fuel "saved"
Old Jun 27, 2012 | 08:31 AM
  #1550
2009G37Bandit's Avatar
2009G37Bandit
I am going Friday for my 2009. Now they haven't checked the VIN because I wasn't in their system and this is my first time in.
He seemed to know about it, so all seems cool. Also bought the MAP Navigation Update $99, BUT they SAID its $109 to install More than the damn Navigatiion Update Itself
Old Jun 27, 2012 | 09:51 AM
  #1551
Dus1101's Avatar
Dus1101
Originally Posted by okrim
Anybody have the new update itb12-27 done in Canada?
Yes - Guelph Infiniti Nissan did my 2011 G37x sedan. I know at least one other person got his G37xS sedan done at another Ontario dealership (not sure which one).
Old Jun 27, 2012 | 10:50 AM
  #1552
jrh710's Avatar
jrh710
Originally Posted by HappyG
I have a 2010 G37x sedan. I done the update couple of weeks ago. I just mentioned about the 7AT lag and my dealer applied the latest TSB without any hesitation or question.
If your dealer continue to give you a hard time, perhaps you could try another dealer.
The service advisor acknowledged both the problem and the new TSB, but still insisted that it did not apply to my car but to "check back soon" to see if the scope expanded to include it. She even double-checked to verify this was the case. Truly bizarre.
Old Jun 27, 2012 | 11:44 AM
  #1553
sniper27's Avatar
sniper27
go to a different dealer. or even a different service advisor to start.
Old Jun 27, 2012 | 12:02 PM
  #1554
trcb777's Avatar
trcb777
I Think I found your problem as soon as you said "she".
Old Jun 27, 2012 | 12:58 PM
  #1555
Chris11LE's Avatar
Chris11LE
I have to report that I feel my car has lost some of the response time it had when the flash was initially installed. Coming out of a turn isnt the instant response I had for the first few days post-flash. I feel a little lag creeping back in during downshifting (especially at highway speeds).
Now the only thing I can think maybe happened is that I ran the car low on fuel. Not sure if that triggers anything, or messes anything up in ECU/TCU "learning" or what, but aside from that there has been nothing out of the ordinary driving/operation wise in my car.
So either the fuel thing messes something up (not permanently if it does, I might try an ECU reset), there is still something bad with the programming, or the tranny is "adapting" in a way that reduces performance. Either way, Im starting to think this might not be as permanent a fix as I had hoped. Not sure if others have had the same experience, but I might give my dealer a call just to tell them what Im experiencing.
Old Jun 27, 2012 | 02:56 PM
  #1556
Marc Collins's Avatar
Marc Collins
Won't be low fuel related. Highly unlikely, but it could be related to lower octane fuel in your tank now. Most likely it is adapting
Old Jun 27, 2012 | 03:23 PM
  #1557
mikeb2004's Avatar
mikeb2004
Interesting, I have not noticed any decrease in "goodness". Yesterday I was driving a little more spiritedly than usual and I was still very pleasantly surprised how quick it is to respond now, whereas before it was endless frustration with it. It's not as downshift-happy as cars from say 5 years ago, and if I jump in one of my other cars and compare, sure it is a bit more reluctant than those. But I believe that is due to the fuel economy goal. I still find that it drops down one or many gears on command within less than a half second or so when I use only my right foot. Now that the thing actually works well, I'm even getting used to simply "picking a gear" with just my right foot. Coming out of a turn it still seems instant-enough to me, I'm not feeling anything even slightly close to the "wait for it" B.S it had before. Still very happy with it, still very drivable and enjoyable (it was NOT at all before).
Old Jun 27, 2012 | 03:27 PM
  #1558
Damn Dirty Ape's Avatar
Damn Dirty Ape
Originally Posted by mikeb2004
Interesting, I have not noticed any decrease in "goodness". Yesterday I was driving a little more spiritedly than usual and I was still very pleasantly surprised how quick it is to respond now, whereas before it was endless frustration with it. It's not as downshift-happy as cars from say 5 years ago, but I believe that is due to the fuel economy mission. I still find that it drops down one or more gears on command. Now that the thing actually works well, I'm even getting used to simply "picking a gear" with just my right foot. Still very happy with it.
my f150 has had several trans flashes and nothing matches the crispness of a new pcm reset. Give it a few days/weeks then kinda meh. Same here most likely.
Old Jun 27, 2012 | 04:15 PM
  #1559
HappyG's Avatar
HappyG
One and only that one day I experienced some slight lags, but not major lags like before the re-flash. It all happened in that one day...my G was kind of temperamental. It cured itself and I haven't experience that again since.
By the way, gas mileage seem to be the same as before the latest update. I can't tell accurately because of my driving pattern is different everyday. But definitely not something noticeable yet.
Old Jun 27, 2012 | 09:27 PM
  #1560
trcb777's Avatar
trcb777
I'm on day two of the update and loving it. The car just seems to always be it the right gear and therefore feels crisp, responsive, and ready to go. I got 28.1 mpg on my drive to work (40 mile) through downtown Atlanta, which is about the same as before. The car really is running good.
