Tuner says 30 hp gain on Cobb
Talked to a tuner in a nearby city, he says utmost he can expect out of a Cobb AP tuning is around 30 hp with gen 3 intake, HFC and CBE. Thats what he got with an Uprev tuning.
I think I'm getting my car has gained about that much after installing above said parts and running pre-loaded Cobb maps.
As per board members results, some of us have gained more than that so is it worth going with this tuner or look for someone else?
since warranty is from Infiniti and you're replacing factory ECU settings with a custom settings, then Yes it does void the warranty.
Cobb does give you the option to save your factory ECU settings to revert back to.
Is that 30 HP from the tune alone, or is he saying all the bolt-ons + the tune will yield 30 HP?
