New problem!
Old Sep 28, 2010 | 01:51 PM
Bahrain5666's Avatar
Bahrain5666
Exclamation New problem!
what can i say?!?!? i started loving my G more even with the problems!!!
i was driving normally and enjoying my baby G all of a sudden the car wont rev more than 3500 rpm!! and check engine light is on!!
i stopped and turned of the car and started again and started driving
same thing ! car wont rev more than 3500 rpm! so i drove safely and slow back home.
i decided to rest the ecu by disconnecting the battery over night, so i did that.
woke up and connecting the battery, no check engine and the car was perfect!
BUT 10 min later the check engine light back on and rpm problem again!
went to a friend and he plugged the thingy ( the code reader thing ) and 2 codes showed:
P0081- IVT CONTROL SOLENOID VALVE
P0524- ENGINE OIL PRESSURE
so, called the dealer and told them and asked me to get the car tomorrow morning but ill send it tonight
anyone with same issue??? or can help?
mods: stillen gen3 - FI test pipes - Invidia exhaust
Old Sep 28, 2010 | 07:24 PM
Staples's Avatar
Staples
I don't specifically know what happened, but the car went into limp mode as a fail safe which is a good thing (which is why it wouldn't rev past 3500rpms and your CEL came on).
Old Sep 28, 2010 | 08:28 PM
PictureMeRolin's Avatar
PictureMeRolin
I'm sure Bill Gates was involved in this somehow. Your car reminds me of my computer.
Old Sep 28, 2010 | 08:35 PM
GraphiteG37S's Avatar
GraphiteG37S
Staples;
How do you normally get your car to enter LIMP MODE? (by running it too hot)
What is the fix for this?
Old Sep 28, 2010 | 09:43 PM
Staples's Avatar
Staples
Originally Posted by Kverd88
Staples;
There's numerous ways to get the car to go into limp mode. Lets say you're tracking your vehicle and you're not running an oil cooler. The oil becomes so hot that the ECU enters limp mode so it doesn't detonate your motor from lack of proper lubrication. The hotter oil becomes the more it thins out. Limp mode goes away after about 20 minutes of having the car off, or enough time to cool things down. It's also a good idea to disconnect the ground on your battery while doing this so it resets your ECU in the process.
I've personally had my car enter limp mode because I get a little bit of dirt on one of my MAF sensors when I was installing my intakes. I cleaned it off real well with brake fluid cleaner and turned the car off, waited 20 minutes, turned it back on and everything was fine. It was a scary experience for me because I wasn't expecting it, so at first I didn't know what the culprit was.
Old Sep 29, 2010 | 04:12 AM
Bahrain5666
i just called the road service and they will pick my car in few minutes and take it to the dealer
called the dealer and talked to the guy there informing him that the car is on the way.
as long as the car is in limp mode then im ok. The 2 codes i got are related to each other and both have to do with the intake valve control solenoid
so lets wait and see! im 100% that its an EVIL EYE!!
Old Sep 30, 2010 | 09:29 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Sorry to hear about it man. Keep us posted.
Old Oct 1, 2010 | 07:35 AM
Bahrain5666
thanx for the replies guys
got a call from the dealer they said the checked he car and cleaned the solenoid. they said that the solenoid was covered with old oil that they changed 2 weeks ago! so they are keeping the car over for the weekend to test it and make sure nothing goes wrong again.
ill update you guys once i get the car
Old Oct 1, 2010 | 12:12 PM
Frankyg37s's Avatar
Frankyg37s
i thought the dealers suck in kingdom of bahrain i thought they only know the nissan tiida lol
good luck with ur G my dude
Old Oct 2, 2010 | 08:48 AM
Bahrain5666
to be honest , they are good but not the best.
they are trying to be great
Old Oct 3, 2010 | 03:12 PM
Bahrain5666
got the car back!!
they cleaned the solenoid and gave me the car... no code no check engine
drove the car for an hour and everything is back to normal, got the infiniti technician with me in the car too... he said give it some hard runs so i was driving between 180-210 km and all of a sudden he said " sir i have two kids " loool
so all good .. will update u if anything goes wrong
Old Oct 3, 2010 | 03:33 PM
advan37's Avatar
advan37
i hope nothing bad happen to you car .
Old Oct 3, 2010 | 06:20 PM
G37Sam's Avatar
G37Sam
Inshallah nothing will go wrong and glad your issue has been resolved.
Old Oct 3, 2010 | 09:09 PM
Bahrain5666
thanx guys
sam i think ill go for the drop that the car is asking for
butwhatuptho
Oct 4, 2015 07:51 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
