HOw to use the auto shifter in manual mode...
Old Sep 22, 2008 | 02:56 PM
fdg911's Avatar
fdg911
Now, I have read all the posts on the paddle shifters, but since I only use one hand on the wheel, I don't see myslef really using it.
However, I would like to really learn how to use the auto shifter in manual mode, without killing the car in the process. I can be an agressive driver, but do not care about gas mileage. I am worried about using the shifter in manual mode and then getting slowed trying to change lanes on the fly on the highway.
Thanks...
Old Sep 22, 2008 | 03:16 PM
DdotRoq's Avatar
DdotRoq
First and foremost, I would not reccomend Paddle Shifters for racing. (on or off the track, it is just not as effective.)
If you want to use it for FUN, its quite easy. Take a 10 mile drive around using only the paddles and you'll see how fun it is. First, if your RPM's drop low enough for your car to stall, the car will automatically downshift for you to prevent stalling. This does not prevent you from blowing your engine. Leave it on 1st gear and don't upshift, you will overrev and burn your engines life.
It is simple - taking it to red line will hurt your engine, as, you state, you are a beginner paddle shifter, you will not be the best. Simply put, to drive "hard", drive it to 1k before redline and shift and the "Paddle Lag" (That may be improved by purchasing wires, something like Black Bettys Grounding Wires - free advertisement for you, BB will most likely put you on the exact redline you want to be at. If you want the most powerful spirited driving or perhaps want the vehicle to shift better than a manual vehicle, leave it on DS Mode. DS Mode shifts great. Paddle shifters has a 1/2 second lag to it, making mastering a bit more difficult.
Hope this helps.
Dave
Old Sep 22, 2008 | 04:20 PM
Hope this helps.
Dave
You da man Ddot Roq!
However, the OP stated he does not want to use the paddles but rather the auto shifter. As a 6MT driver, I can't help with that but thanks for the gratuitous plug for my product.
Old Sep 22, 2008 | 04:42 PM
Infinite G37S's Avatar
Infinite G37S
Does the ground kit really improve the lag?
Old Sep 22, 2008 | 05:27 PM
fdg911's Avatar
fdg911
Exactly, I stated I DO NOT want to use the paddles, but only the DS mode...
but thanks...
Old Sep 22, 2008 | 06:21 PM
tfmbigdog99's Avatar
tfmbigdog99
From: Where the kids are high and the grades are low. NYC
Be honest I really enjoy the car just in DS. Throttle is extremely responsive and always quick at a nice RPM. Auto-shifting is gay unless your going from a dig with some 328i beemer.
Old Sep 22, 2008 | 08:52 PM
Geepers's Avatar
Geepers
DS Mode!
Old Sep 22, 2008 | 08:56 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Just be careful downshifting into 1st in MM it lags pretty bad almost had a few accidents when I first got the car. The rev matching is different than my G35 was took some time to get used to.
Old Sep 22, 2008 | 10:44 PM
sahiwal007's Avatar
sahiwal007
whats the correct rpms to upshift and downshift in triptronic mode?
lets say for 1st gear shift at what rpm? 2nd.... 3rd....and so on
Old Sep 22, 2008 | 10:53 PM
Skyline-LEXY's Avatar
Skyline-LEXY
tag
Old Sep 23, 2008 | 08:37 AM
04STi208G37's Avatar
04STi208G37
yes
Originally Posted by Geepers
DS Mode!
+1
There is a lot of range. Personal Preference Really. Don't be afraid to play and learn. It's not that hard to master
Old Sep 23, 2008 | 08:42 PM
Skyline-LEXY
Correct me if i am wrong... i heard someone said dont pass 2000 rmp at 1st gear. is that correct?
Old Sep 23, 2008 | 11:14 PM
Thrillhouse's Avatar
Thrillhouse
This is completely false. The car has a redline for a reason. 7500RPM is the maximum safe speed that Nissan says the engine can operate at. You could drive down the road banging off the rev limiter as long as you want, and provided the cooling system can keep up, you'll never hurt the engine.
The optimum shift point on the G37 is right at redline. the VQ37 doesn't have a big dropoff like some other cars, so for fastest acceleration you'd want to shift right around 7500.
You will not hurt the car by shifting at redline. I drove an entire track day shifting at or above 6500RPM and my car is just fine.
The car has a computer controlling the transmission. It won't let you do anything that can hurt anything. It's not like the 6MT where you could pop the motor by putting it in second at 100mph. Do whatever you want with the paddles, nothing bad will happen. Just remember what works well and what doesn't and you'll figure it out in no time.
37
Oct 17, 2020 11:12 AM
k19g37x
Sep 29, 2015 02:46 PM
mikysee
Sep 28, 2015 11:18 AM
