Blackstone Laboratories Oil Analysis Reports
Old Nov 10, 2017 | 10:38 AM
  #301
Victory's Avatar
Victory
Decided to have an analysis run before the drivetrain warranty expired. Engine was formerly sludged by the lessee. This is post cleanup, 4200mi run with Pennzoil Ultra platinum. Numbers are good. Gonna go longer next time.
Old Nov 21, 2017 | 09:00 AM
  #302
fonthill's Avatar
fonthill
He's most likely using the Mobile 1 M-108 oil filter. I've been using this combination since I purchased my car.
That is what I have been using.. 10k miles no problem they said with the combination.. I do have to top it up once in a while when I have spirited runs
Old Dec 5, 2017 | 07:09 PM
  #303
BigRek718's Avatar
BigRek718
First oil change after I bought the car in June of 2017.
Old Dec 5, 2017 | 11:11 PM
  #304
PNW_IPL's Avatar
PNW_IPL
How many miles on her?
I've been meaning to do mine since i bought her two years ago.
Old Dec 7, 2017 | 09:06 PM
  #305
BigRek718's Avatar
BigRek718
I have about 35k on her now.
Old Mar 10, 2018 | 05:07 PM
  #306
Randy Johnson's Avatar
Randy Johnson
Blackstone Labs Oil Analysis
Vehicle: 2010 G37S Stock no mods
Milelage: 80000
Fuel 93 octane
Driving: Mostly city this past year. 80/20
File Type: pdf
Old Mar 27, 2018 | 10:29 AM
  #307
projectpanda13's Avatar
projectpanda13
I got my car at 60,000 miles, and have been using Castrol Edge Titanium 5W30
up to my last oil change at 99,000 miles. This report reflects my last oil change with an interval use of 6,300 miles.
I switched to Mobil 1 0W40 and will get another UOS on the next oil change.
Latez
Old Apr 29, 2018 | 10:12 AM
  #308
NOBOX7's Avatar
NOBOX7
check this out
Old Apr 29, 2018 | 11:59 AM
  #309
hobbs's Avatar
hobbs
Who paid for that advertisement?
Old Apr 29, 2018 | 03:15 PM
  #310
Infinita Chica's Avatar
Infinita Chica
My apologies, but I'm not sure how to interpret the numbers. The overall outcomes from the available data suggest what with respect to "best" oils for the 37's? Essentially:
  1. Which top 3 oils have the best wear numbers overall?
  2. Which bottom 3 oils have the worst wear numbers?
Thank you in advance.
Old Apr 29, 2018 | 03:54 PM
  #311
slartibartfast's Avatar
slartibartfast
From Blackstone:
"Ok, now for the technical questions. What is a TBN?
A TBN (total base number) measures the amount of active additive left in a sample of oil. The TBN is useful for people who want to extend their oil usage far beyond the normal range.
Do I need to send in a separate sample for a TBN?
No. We can run your TBN on the same sample of engine oil you send. It's also not necessary to send in a sample of virgin oil for a TBN. You're welcome to do so, of course, and many people do this to see where the TBN starts out. If you do send in the virgin oil sample, the cost for that sample is the same as for your used engine oil sample.
The TBN is based on the level of calcium sulfinate and magnesium sulfinate in the oil..."
Why best three? Why not absolute best? Motor oil is one of those never-ending discussions, like white bread vs wheat bread or "less filling/tastes great". Pick a quality oil of the appropriate grade and change it regularly.
Old May 10, 2018 | 04:16 AM
  #312
milosz's Avatar
milosz
From: Chicago home of the 2016 world-champion Cubs!
Blackstone results
I am trying to understand the iron level result. Does it mean anything about the engine, or the kind of driving I do?
Also, I wonder where the iron is mostly coming from- the valve train / timing chain & parts? Camshafts? Crank? Just curiosity.
Right now, my car is under CPO warranty so I am sticking to Infiniti's 7,000 miles OR 7 month oil change "rules" - but after the CPO warranty runs out, I will probably go with a 12 month oil & filter change routine, I drive less than 5,000 miles in 12 months. The oil in this analysis had lots of life left in it - lots of neutralizing ability and lubricating properties left after 7 months / less than 3,000 miles, so I am pretty sure 12 months / 5~6,000 miles will be just fine.
Blackstone oil analysis
Old May 10, 2018 | 09:31 PM
  #313
slartibartfast
Most of the iron will come from cams and valve gear in our engine. The crank is iron, too, so that's a source.
Old May 11, 2018 | 04:49 AM
  #314
milosz's Avatar
milosz
That all makes sense. The variable valve timing mechanicals are an area of intense action, so much so that Nissan puts an oil temp sensor there. The valve train - LOTS of moving parts, so I kind of figured this would be a source of iron. And the crank, too, a fair amount of area.
I can also picture how a lot of start - stop driving would put stress on all these parts that you wouldn't get with the smoother action of more constant driving.
I wonder what oil analysis results look like from guys who take their cars to the track.
Old May 11, 2018 | 07:35 AM
  #315
slartibartfast
I had an analysis done a few weeks ago, oil had two track events on it. Need to get a round TOIT and post it here.
