Blackstone Laboratories Oil Analysis Reports
Old Jun 28, 2018 | 01:48 PM
  #316
projectpanda13's Avatar
projectpanda13
This is the second sample I just got back. This is comparing to the Castrol Edge 5w30 I ran the first time.
Latez
Old Sep 15, 2018 | 05:14 PM
  #317
SFLG37S's Avatar
SFLG37S
Latez
I used Castrol Edge on my S54 BMW and it kept away the dreaded rod bearing wear. Warming up before driving hard helps too.
Old Nov 6, 2018 | 08:37 AM
  #318
Eugenius's Avatar
Eugenius
Here is automatic transmission fluid test. I did 3 times a single drain and refill (not flush) at 45K miles, at 66 K, and 78K.
Looks like it works, no issues so far
ATF test
Old Feb 27, 2019 | 07:59 PM
  #319
Dzionassi's Avatar
Dzionassi
Well, had my first test. Not happy. Iron levels extremely high. Had car since new, 26k miles at this moment.
It is tuned with few bolt ons. Anybody can provide some insight?
Old Feb 27, 2019 | 08:03 PM
  #320
bythabay's Avatar
bythabay
20 Year Member
Iron is usually from top end wear or the other parts as they described. What’s the car tuned on ? What are the conditions it’s seeing? Has the knock sensitivity of the engine been adjusted?
Old Feb 27, 2019 | 08:07 PM
  #321
Dzionassi's Avatar
Dzionassi
Ecutek by Seb. it is in Chicago. 30 miles a day (50/50 city/highway) with few WOT
Old Feb 27, 2019 | 08:46 PM
  #322
saywat?'s Avatar
saywat?
^wat oil brand do u use?
Old Feb 27, 2019 | 08:50 PM
  #323
Dzionassi's Avatar
Dzionassi
Pennzoil Ultra Platinum
Old Apr 24, 2019 | 09:00 AM
  #324
afrayedknot's Avatar
afrayedknot
Used Oil Analysis - Mobil 1 0W40
Just out of curiosity, I decided to get a used oil analysis from Blackstone Labs on the Mobil 1 0W40 full synthetic oil I have been running in my G37. The results look great. The viscosity is fine and I was recommended an OCI of 9,000 miles. Hopefully this serves to relieve any worries that one might have about using 0w40 instead of the Infiniti recommended 5w30.
Old Apr 24, 2019 | 09:06 AM
  #325
4doorfury's Avatar
4doorfury
Out of curiosity, why the switch to the European formula? Just wondering because I have a bulk supply for my my Mercedes and if I can keep same oil for both cars win win for me
Old Apr 24, 2019 | 09:39 AM
  #326
projectpanda13
My Mobil1 0w40 UOA reference post.
The link above is my analysis on the same weight. I also had good result, also less engine ticking, but I burned a bit of oil and now switched back to 5w30. I wanted to try the 0w40 because from everyone else's report it flows similar to a 30 weight despite it being a 40 and the 0 helped with getting oil circulated around quicker initially, which might be a reason for the quieter noise?
Old Apr 24, 2019 | 09:58 AM
  #327
afrayedknot
I tend to get really obsessed with things when there's a discrepancy. There was, and probably still is, a lot of debate between 5w30 vs 0w40 and which one is better for engine longevity. I found countless threads that argued that the 0w40 was superior than 5w30. Reasons for preferring 0w40 ranged from "improved shear resistance" to "they use it in the GTR". There's also quite a bit of anecdotal evidence out there advocating that the engine runs smoother and less noisy after switching to 0w40. This thread is what finally convinced me to switch over. https://www.myg37.com/forums/engine-...oncerns-2.html FWIW I have been using 0w40 for the last 15,000 miles.
Old Apr 24, 2019 | 10:00 AM
  #328
afrayedknot
This might seem like common sense, but how do you accurately determine if there's oil loss? Do you measure the fill and drain amount (in oz?) during the oil change? Looking at the dip stick level does not seem accurate at all...
Old Apr 24, 2019 | 10:06 AM
  #329
afrayedknot
Mobil 1 0W40 UOA / Mobil 1 - 110A filter - 75% city driving
Old Apr 24, 2019 | 10:07 AM
  #330
projectpanda13
I usually check my oil once a week on weekend mornings, and I had to add a quart during my usage with 0w40 both Mobil 1 and Castrol Edge, around 3000 mile mark. I switched back to 5w30 and I haven't had to add any oil as or yet, but I haven't reached 3000 miles yet.
