how to reset ECU w/out disconnecting battery?
Old Dec 9, 2007 | 12:11 AM
]\[ /-\ ]\/['s Avatar
some reason I'm not allowed to post or make any replies to the threads in the FAQ & DIY forum...anyway, I followed the instructions posted in the FAQ & DIY by DiamondGcoupe found here https://www.myg37.com/forums/d-i-y-installations-modifications/175792-easy-way-to-reset-ecu-without-battery-disconnect.html
but have no luck...anyone else able to do this ecu reset?
Old Dec 9, 2007 | 01:47 AM
CrazyRuskie's Avatar
CrazyRuskie
Crazy Russian Super Mod
Timing is everything with this. I haven't tried it myself, but I did reset my ECU on my 03 Coupe and it took quite a few tries before I got it right. It should work, just gotta time everything perfectly.
Old Dec 9, 2007 | 02:07 AM
i've tried it at least 10x...lost count
going to go back to the ancient times and disconnect the battery and leave it overnite
Old Dec 9, 2007 | 08:47 AM
DiamondGCoupe's Avatar
DiamondGCoupe
Yeah its just something you gotta keep trying unfortunately. This took me about 4-5 try's before I got it on my old coupe but I assure you it does work, just takes a little practice. I'll see what I can doo about making a video maybe that will make things a lot easier if you can "see" the process and how to time it properly. There's nothing wrong with disconnecting the battery I just dislike having to reset my radio presets.
Old Dec 9, 2007 | 02:23 PM
finagle69's Avatar
finagle69
i wasn't able to do it until i used a stopwatch. now i can get it every time... if i use the stopwatch.
Old Dec 9, 2007 | 03:29 PM
LOL...i was thinking bout using a stop watch....but thought that's crazy, i shouldn't have to use a stopwatch for this hahah
Old Dec 9, 2007 | 07:30 PM
DiamondGCoupe
Well if you can't count slowly enough the stopwatch is your best bet. There's a 99% chance you doing one or more steps too fast, so use the stopwatch ONCE and as soon as you did you won't ever need it again.
Old Dec 10, 2007 | 11:02 PM
iansw's Avatar
iansw
My internal clock must be right on. Worked for me 1st try.
Old Dec 11, 2007 | 12:22 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Works for me each time. I have a clock in my garage- I normally just watch the clock as I am doing my steps. As long as yout timing is close, it should work.
Old Dec 11, 2007 | 01:09 AM
vinnys coupe's Avatar
vinnys coupe
dont you guys seem bad flooring your car for 10 seconds.. like that beast lol. i dont think i would have the ballz to do that
Old Dec 11, 2007 | 01:18 AM
car isnt running
Old Dec 11, 2007 | 07:47 PM
Dieseldoug22's Avatar
Dieseldoug22
Help!! I have tried it many times. I can get to the first ten second interval and the Service engine lit blinks after 8 seconds, I wait until 10 then release and within 1 second I am back on the throttle for another 10 seconds. After about 6 seconds the engine light stays on constant and nothing else happens. what am I doing wrong. I am using a stopwatch. How long do you wait before you reapply the throttle for the second 10 second time?
Old Dec 11, 2007 | 10:16 PM
DiamondGCoupe
Immediately, release the gas then re-floor until the C.E.L. starts blinking fastER.
vamarris
Dec 9, 2018 11:10 AM
delfinparis
Oct 8, 2015 06:06 PM
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
