Drivetrain Reviews of clutches, gear mods, diffs, axles etc..
Review Bell Raceworks rear differential brace
Old Feb 5, 2019 | 06:07 PM
  #106
Originally Posted by 4DRZ
I bet! "She falls in a well, eyes go crossed. She gets kicked by a mule. They go back to normal. I don't know." -Uncle Eddie
Swing and a miss there, Clark. It's Cousin Eddie.
Old Feb 5, 2019 | 06:55 PM
  #107
JSolo's Avatar
JSolo
Just say no!!!!!
Maybe instead of side by side pics, is an overlay possible?
Old Feb 6, 2019 | 08:33 AM
  #108
Bravo at's Avatar
Bravo at
Torque Spec Recommendations for OEM Brace
Originally Posted by thezinfan
You are correct. I also couldn't figure out a way to get a torque wrench in there.
What is the torque recommendation for the two bolts connecting the OEM brace to the subframe?
Ordering my OEM brace today...
Old Feb 6, 2019 | 08:43 AM
  #109
32 ft/lb torque for the two M10 bolts in the diff cover
25 ft/lb torque for the two M8 subframe bolts on the OEM cover brace
45 ft/lb torque for the one M12 subframe bolt on the Z1 cover brace
Old Feb 6, 2019 | 08:53 AM
  #110
Entcee's Avatar
Entcee
Ask and you shall receive
Old Feb 6, 2019 | 11:40 PM
  #111
jpowersjr2's Avatar
jpowersjr2
That Christmas Vacation quote made my night lol.
Old Feb 7, 2019 | 08:00 PM
  #112
4DRZ's Avatar
4DRZ
Haha! One of my favorite movies. So many good lines.
Old Feb 9, 2019 | 07:44 PM
  #113
Old Feb 10, 2019 | 02:54 PM
  #114
Although 35°F outside, it was also sunny and dry, so I pulled the G into the driveway and ran the back end up on ramps... so that I could scope out the situation. I've got the OEM-style diff brace from Bell Raceworks.
I see the two subframe holes intended for the brace, and understand now about the need for an angled wrench to hold the top in place while you torque up from the bottom. Whether you go bolt up or bolt down, doesn't matter. I would say it makes more sense to do the bolt pushed through from the upside, but you would want to adhere the washer to the bolt head first. Otherwise you'll go insane fishing loose pieces through the subframe. That "oops I dropped it" situation seems inevitable.
I also see how the upper diff cover bolt is a PITA for access with the brace in place. That sucks.
So after eyeballing the situation... I'm leaning towards having the shop install the brace in the spring, same time as I have the engine mounts replaced. Having the car on a lift would be vastly more efficient. Should be a 20 minute process, in and out. But on my back in the driveway, I can see this getting pretty frustrating.
I don't know. Perhaps this is something better looked at a second time in warmer weather. I would need to figure out a way to confidently slip the bolts into place without losing them in the subframe, and a way to secure the bolt heads inside the subframe while torquing them from the bottom. I believe the right name for that tool is "offset box head wrench".
Old Feb 11, 2019 | 09:22 PM
  #115
Entcee's Avatar
Entcee
Received the replacement today, and that one fit like a glove. Also found the problem. One "tube" was not quite square.
Initial impressions with a 20 minute test drive..... Wow, what a difference!
  • No added NVH, not even a little. Granted I have subframe collars, etc... already.
  • Shifts (not only shifting, but also clutch modulation) seem.... smother? A little less sloppy? Improved!
  • The entire rear end seems less sloppy.
  • May have helped clutch chatter.
  • Reduced, and may have eliminated wheel hop. <--- slartibartfast has been waiting for that report
Some of this may be placebo, but I can definitely feel a difference. Worth every penny. And, I should note, Arthur Bell's customer service is outstanding. If it wasn't for the Post Office, the replacement brace would have arrived on Friday.
Excuse the dirty underside.
Old Feb 12, 2019 | 10:33 AM
  #116
4DRZ's Avatar
4DRZ
Glad to hear you are enjoying the brace. I am also in to hear about reduced wheel hop. It looks like I will have to wait a bit longer to experiment myself with this since we are getting a foot + of snow today.
Old Feb 12, 2019 | 11:15 AM
  #117
Entcee's Avatar
Entcee
Yeah, I need to do further testing, I just half-heartedly tried once and there was 0 wheel hop. While not definitive, it seems promising.
Sorry you are getting snow. That is one reason I don't move back to Colorado.
Old Feb 12, 2019 | 11:32 AM
  #118
4DRZ's Avatar
4DRZ
I don't mind the snow. I like driving in it, but it is a lot more fun with AWD.
Old Feb 13, 2019 | 05:55 AM
  #119
bryanscott's Avatar
bryanscott
If my stock diff bushing is ok, would this be better to go with or just replace the diff bushing first? Or can i skip the pain of replacing the diff with this route lol.
Old Feb 13, 2019 | 06:24 AM
  #120
The Pope's Avatar
The Pope
My stock diff bushing is ok, so I skip the pain of replacing it and I'll see how long the OEM survives with this bracket installed.
That's the best answer that I can provide. Time will tell if my decision was correct or not.
