Review TWM Short Throw Shifter (STS) and Z1 Transmission Mount
Actually, I didn't learn about Vibra-Technics on a 370z forum; I found out about it right here:
This forum actually is informative
So, back to the mount, I'm starting to have negative thoughts about this constant growl. On the drive home it was all highway with no traffic, and I can see myself getting tired of this constant growl when cruising. I love the sound when accelerating, but at highway speeds, the sound reminds me of exhaust drone. I'm not saying they sound alike, I'm talking more about how the sounds present themselves, as in, constant and always noticeable.
Maybe I should give it some more time.
Hallelujah!
I think I found exactly what I've been looking for. A UK company called Vibra-Technics makes aftermarket mounts that use rubber bushings that are better than OEM ones but not hard as a rock like urethane or solid metal ones. A little more expensive, but not unreasonable.
370z - Vibra-Technics Compliance Technology
You guys are funny. Didn't you install the on/off switch? LOL
Personally, I love what this mount brings to the car, and I think it's obvious that I'm very particular about what I do or don't like. As said many different ways, people have different tollerances for NVH... although it is funny that the old guy digs this.
Two weeks into this mod now, and its just normal again.
Do you have a link to the thread where BB posted that? I haven't found very much info on this mount, besides your feedback.
Two weeks into this mod now, and its just normal again.It didn't really occur to me until the other day that the extra noise is exactly what I experienced on my Subaru with a stiffer transmission mount. At first, I installed rear differential bushings and transmission crossmember bushings and loved it. So then I added a stiffer transmission mount. Lots of growl, and an oh-so-slight increase in vibration. Reviews were mixed, similar to this, as to if the growl was too much.
I have a quiet setup, so in someways, I'm OK with extra noise, as long as it's not obnoxious and I can still shuffle the wife and kids around without objections.
https://www.myg37.com/forums/g37-cou...on-mounts.html
Lego, I think you'll be fine, particularly with the rubber mount. And if not, removal is just as inexpensive labor as installation, and you simply sell it here at a reasonable discount. No harm, minor loss.
Noise is speed related.
FI RHFC, Tanabe Y Pipe, 2.25" custom midpipe with 22" resonators and Borla Boomer mufflers.
I may be in the minority here, but I think I'd prefer a little more vibration for a little less noise with this mount.
The primary reason I went with a stiffer mount though, was for performance, not an increase in NVH, regardless if it's mostly good NVH. And right now, I can't tell if it's providing better performance than the stock mount.
I'm planning to get a tune within a month, so since the mount is so easy to replace, I might have my tuner do a few pulls with each mount, to see if it's actually transferring more torque to the rear wheels.
Our transmission is a little unusual and does not have a typical 2 point mounting system. It only has a single mount. This means the engine mounts are the only part that controls how much the driveline winds up.
