BC Racing coilovers - rear preload/height adjustment question
Old Feb 11, 2019 | 10:40 PM
Infinibini's Avatar
Infinibini
Hello all,
My BC Racing coilovers just arrived in the mail. I read through the instructions and I just want to make sure I understand everything. When I adjust the front right height, I need to move the top and bottom rings at the same time so that I don't change the compression of the shock. That seems logical.
For the rear, since the shock and spring are separate, the instructions say set my ride height with the spring perch and then jack up the car until the hole lines up for the shock mount. So do they mean set my ride height and then hub up and as it goes up, turn the adjuster ring on the strut until the spring is touching the top and bottom of the mounts, and then tighten up the strut adjuster? Basically make it neutral when the spring is neutral?
And I guess it would be the same for the front - adjust my ride height and then move the bottom ring until the spring is just a tiny bit tightened past the neutral position. Is this right?
I am planning to install in the next two weeks if I can find time. I want to make sure I don't run into any surprises.
Thank you
Old Feb 15, 2019 | 11:51 PM
Infinibini's Avatar
Infinibini
I think I figured it out after thinking about it for awhile and messing with the struts. Now I see the idea of keeping the preload and strut compression the same no matter what the ride height is.
xnick101
Dec 2, 2016 11:40 PM
VQCrew
Dec 13, 2015 01:59 PM
shawnberry45
Jan 9, 2015 05:10 PM
RogerRab
16
Jan 22, 2014 12:29 PM
GeeeeOhhhh
Jul 21, 2010 02:03 PM
