Help G37 BC Coilovers Front Height Adjustment Problem.
Old Jul 21, 2010 | 11:48 AM
GeeeeOhhhh's Avatar
GeeeeOhhhh
Searched the Internet & Forums and couldn't find an exact answer on how to adjust the front height of the BC Coilovers for the G37.
I loosened the bottom ring and removed the brake lines and abs sensor from the bottom shaft but it barely turned. i might have got it to turn 1/2 way before giving up.
The rears were easy, i just unscrewed the bottom ring and turned the coilovers til i got the specific distance then locked the thread but the fronts don't seem like that since the springs are on the coilovers.
Please help!
Old Jul 21, 2010 | 12:35 PM
soundmike's Avatar
soundmike
For the fronts there are three rings - top, middle and bottom.
For adjusting height, you loosen the bottom but use the top and middle to adjust (without loosening those).
After loosening the bottom, verify that the top and middle rings are snug against each other then proceed as follows.
Using the provided spanner wrenches:
To lower, turn the Top ring counter clock-wise (right to left)
To raise, turn the Middle ring clock-wise (left to right)
If you turn the wrong ring the wrong way, then it will loosen the rings and/or change the pre-load. You know you're doing it right because the cartridge height will change, not the spring height.
For the rears, after adjusting the springs, make sure you adjust the strut length according to BC's recommendations at the bottom of this page.
Also, a tip, brush and air blow the threads prior to doing this.
Old Jul 21, 2010 | 12:36 PM
soundmike's Avatar
soundmike
p.s. Found this, too.
Old Jul 21, 2010 | 01:09 PM
GeeeeOhhhh's Avatar
GeeeeOhhhh
Thanks mike i'll try it tonight!
Old Jul 21, 2010 | 01:25 PM
Kidcane's Avatar
Kidcane
Florida G Club
Yep what he said.
Old Jul 21, 2010 | 01:48 PM
g37mobbber's Avatar
g37mobbber
i wish i could tell you how to do it, but amplified did my height adjustments for me!
Old Jul 21, 2010 | 02:03 PM
GeeeeOhhhh's Avatar
GeeeeOhhhh
i'm sure the directions mike gave me will clear up the confusion i was trying to twist the bottom end when i should be twisting from the top just like the rear springs. didn't know i had to turn the upper lock ring...
SS2006
Aug 27, 2024 07:33 PM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
m3clubracer
Sep 11, 2016 09:01 PM
MeatySock
Aug 14, 2015 08:25 AM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
