DIY: Stripped cat/header bolt, help!
Old Feb 17, 2019 | 08:32 PM
Searley86's Avatar
Searley86
Hey all,
I was fitting some new HFC, (old ones installed by a mechanic so demon bolt was not going to be an issue) and the stud from the manifold side has been partially stripped (I'm guessing by the mechanic). Because of this I can't get a good seal and my lovely G sounds like a tractor thanks to the exhaust leak. I'm thinking a tap and die set could be used to re-thread the boot, but there isn't a huge amount of room to manouver, any other ideas of how to solve this problem?
Huge thanks in advance.
Old Feb 18, 2019 | 09:19 AM
Baadnewsburr's Avatar
Baadnewsburr
Tapping and rethreading is ghe best solution you can try to also put som high heat (copper) permatex on the gasket to seal it too but it all require disassembly to a certain extent
Old Feb 18, 2019 | 01:16 PM
Searley86's Avatar
Searley86
Thanks for your reply, disassembly shouldn't be too bad, fingers crossed I can rethread!
MrJCole13
31
Sep 9, 2020 08:32 PM
OMG35S
32
Nov 23, 2015 11:41 PM
RedG37SNC
Aug 15, 2008 04:03 PM
