DIY: Water pump questions & DIY info
Old Dec 8, 2018 | 10:27 PM
  #46
Jamie Nguyen's Avatar
Jamie Nguyen
Originally Posted by Jsolo
Any spare parts left? 👍
old water pump, old thermostat, old lug nuts and old oil galley o rings lol
Old Dec 9, 2018 | 10:57 PM
  #47
Jamie Nguyen
Originally Posted by Hashim
Fantastic write up and great pics, I'm with newt this needs sticky status....
for the the gasket separation, i use this little guy https://www.amazon.com/Engine-Transmissions-Oil-Pan-Separator/dp/B011DR95WM/ref=sr_1_1?ie=UTF8&qid=1544107976&sr=8-1&keywords=Oil+Pan+Separator, its the same tool called for in the FSM. Its basically a blade with a heavy metal block and a tiny handle attached to it so you can hit it with a ball peen ... I'm not sure if its actually faster (but I think it is) but its really good for preventing marring the metal surfaces and lets you get the parts apart without having to "peel" them and potentially warp them
question though, what are the arrows you put on the picture with the cam chains lining up with where the orange chain links are? ...I dont see any marking on the rear cover on those sides? Am i missing something (i'm sure its in the FSM but real pics like the ones you posted are so much easier to work off)
also, what silicone lube did you use on the o rings?
pictureof the silicone lubricant and other stuff I used
sealed my pan with Hondabond bc of the thansands of cars I’ve worked on I’ve yet to see one leak to date and bc my three bond was expired I won’t knock anything that’s never failed
nissan coolant for cheaper same thing
07_g35
Sep 26, 2022 02:10 PM
Jamie Nguyen
47
Dec 16, 2018 02:55 PM
nightmareuki
Jul 13, 2016 01:39 AM
m0nkey
General Tech Questions
Jan 14, 2015 10:35 PM
who4ever
Oct 27, 2011 01:26 PM
