DIY: Whiteline Differential bushings
Old Mar 27, 2013 | 01:16 PM
TVPostSound's Avatar
TVPostSound
You poked the bottom of the busing with a knife to drain out the silicone? Do you have to puncture the top as well? Would simply drilling into it work as well? What size bit did you use? Did you have any problem cutting through the outer sleeve and into the cross member?
I used a knife to drain it, just the bottom, so the drill wouldn't splatter silicone all over the place while spinning!!!
I used one that fit without binding.
The outer sleeve cut like butter with a 24T Sawzall blade. Tool all of 30 seconds.
Had to stop, a couple of times to make sure I wasnt going too far!!
The Sawzall was at a slight rotation angle so I would drag on the center sleeve.
Once it went through the tension was all but gone.
I didnt cut the crossmember.
Old Mar 27, 2013 | 01:34 PM
NeverBoneStock's Avatar
NeverBoneStock
Nice .. I will be attempting to do this when the CF Driveshaft is available so I can knock it all out at once . I have the Whiteline bushings and my SPL parts are starting to trickle in . Question .... Do you know if freezing the diff bushing makes for a easier install ? I keep seeing mixed reviews on that
Old Mar 27, 2013 | 01:45 PM
TVPostSound
The Whiteline? Dont freeze.
If I had a hoist, I probably would have been able to push it in by hand!!
Im on my back with jackstands!!
Old Mar 27, 2013 | 02:02 PM
Modme's Avatar
Modme
Do the front round plates fit inside the subframe hole? I was planning to use them as a press plates to pull out the bushing. This is what im talking about:
Old Mar 27, 2013 | 02:14 PM
TVPostSound
Bad link.
Old Mar 27, 2013 | 02:18 PM
TVPostSound
If you're referring to his no drop no clamp DIY, he revised his DIY, to drill and Sawzall method, which I used. See his post #12
The rear almost falls out, and the fronts just pop out with a hammer and socket.
Old Mar 27, 2013 | 02:27 PM
Modme's Avatar
Modme
Yeah, I'm still going to try the Frankenstein socket method. With the Sawzall method, it seems like you still need a long bolt and a bracket to pull in the new bushing.
Old Mar 27, 2013 | 02:37 PM
TVPostSound
The reason being, that the bushing is egg shaped, and getting it in takes some effort. It wants to pop back out. Once in, it takes little pressure to pull it from the rear. In my case, as I was on my back.
If youre on a hoist, then pushing it in from the front, while standing, should be really easy.
Old Mar 28, 2013 | 10:51 AM
Thanks for this thread and the photos and instruction as to how you did it. Great job.
Old Mar 28, 2013 | 01:06 PM
eVitO's Avatar
eVitO
Just curious, the only reason you drained the diff was because you installed the new cover, right? Or am I missing something?
Old Mar 28, 2013 | 01:29 PM
TVPostSound
Yup!!!
Doing the bushing was a great excuse to do the Nismo cover.
TVPostSound
Thanks for the sticky!!DOMO
Old Mar 28, 2013 | 05:31 PM
Tazicon's Avatar
Tazicon
Nice write up, this will be happening with the Z in the near future.
Old Apr 16, 2013 | 01:04 PM
  #29
Modme's Avatar
Modme
I did my whiteline bushing install this past weekend. It was more PIA than I expected. I have some extra bracing in the way, so it took a bit longer. Tvpostsound did a great write up and I don't have much to add. Sawzall is the way to go in terms of removing the center bushing.
Old Apr 16, 2013 | 02:04 PM
  #30
TVPostSound
Lets add your pic to this!!
