DIY: Replacing front wheel bearings for RWD G37
Old Jan 29, 2019 | 02:49 PM
Baadnewsburr's Avatar
Baadnewsburr
working it out in a criss cross is good advice... it may also be stuck in from dissimilar metal corrosion (forgot what its actually called)...from the aluminm knucke and the steel bearing assembly being in contact and being exposed to the elements...you could try soaking it in PB blaster for a while in conjunction with Seacash's advice..also you could try a slide hammer as mentioned a few posts back
Old Aug 14, 2020 | 03:10 PM
PandaX's Avatar
PandaX
Anyone use 3M copper anti-seize on these wheel hub bolts? What's about 3M copper anti-seize on axle nut for my AWD 13' G37x?
Old Jul 21, 2021 | 07:19 PM
nycqtplayazz's Avatar
nycqtplayazz
How long did this process take?
Old Oct 11, 2021 | 04:44 PM
MP-In-The-Wind's Avatar
MP-In-The-Wind
Good write up...BTW: It took me ~4hours to do...but I also spent that working on my exhaust system too.
Old Oct 11, 2021 | 05:48 PM
VibrantSedan13's Avatar
VibrantSedan13
i just did this over the weekend. Both hubs were seized to the spindle. Lots of hammering and cussing
Old Oct 13, 2021 | 06:55 PM
MP-In-The-Wind
Agreed...lots of pounding to get it out... Perhaps a slide hammer should have been used?!? I will give that a shot if I have to do my RF..
Old Jul 31, 2022 | 09:37 PM
jonathanvaljean's Avatar
jonathanvaljean
Thanks for the write-up!
Thanks for this excellent DIY!
Also, I want to add my name to the list of folks who had to do a bit of hammering to get off (knock off) the front wheel hub. After the rubber mallet proved ineffective over the course of 10 minutes, I resorted to a WD40 and 4-lb sledgehammer.
I will be sure to try the crisscross method suggested by seancash when I have to do another.
Old Aug 1, 2022 | 12:14 PM
rotarymike's Avatar
rotarymike
Moderator in Moderation
Another alternative is using a bolt and nut to press the hub out - see my thread starting here https://www.myg37.com/forums/build-t...ml#post4310207
Old Aug 1, 2022 | 11:14 PM
jonathanvaljean
Great idea, Mike! (Like you, I don't understand why a threaded boss isn't included on the wheel hubs!)
Old Aug 2, 2022 | 09:37 AM
rotarymike's Avatar
rotarymike
Just be aware that it is likely you will ruin even a grade 8 / 10.9 bolt doing this. Those aren't cheap LOL
Old Aug 29, 2023 | 10:19 PM
JUANPCM's Avatar
JUANPCM
Hi, I need to replace my front wheel bearing, i found this post, OP mention the brand and part number, TIMKEN Part # HA590376, now when i do a search every auto parts shops, it never shows up as compatible part, even rockauto shows a bunch but not that 1, they have it, but it wont show up searching parts for my car, I have a 08 G37S Coupe, will it vary from lets say a sedan to a coupe, or S and no S? in the photos it looks like the same as mine, will this TIMKEN HA590376 fit my car? I saw some around $40 and a bit more on rockauto, but Im going for Timken since I read good reviews here.
Thanks!
Old Aug 30, 2023 | 08:54 AM
ILM-NC G37S's Avatar
ILM-NC G37S
I checked the part finder at Timken and the part numbers are correct:
Front: Timken HA590376;
Rear: Timken HA590255:
Then, I searched rockauto.com for a 2008 and came up with the same part #'s:
Old May 8, 2026 | 06:35 PM
Texas Boy's Avatar
Texas Boy
In case it's helpful, I just had my driver's side front go out at 253k mi (R done a few years ago). I know the noise from inside so I figured it out, but there was not any play in the wheel when pulled at 12 and 6 o'clock. However over time with more miles the "roar" inside the car got louder and when using hands on tread of the tire and spinning wheel quickly you could hear the hub "roar" standing in front of it. I was hard-pressed to do this job without hearing the noise while standing beside car lol. My bolt for the ABS sensor is broken off however so I'm coming up with an easy solution. It fits in the knuckle pretty tight but I want to use a flexible chemical to hold it there or somehow remove the bolt and put in a fresh one.
Jonedward
Jul 17, 2019 09:09 PM
Dillons VQ37
Sep 3, 2017 06:09 PM
G37Sam
12
Apr 4, 2012 01:08 PM
