How to Remove the Fake Wood door finisher?
Old Oct 1, 2009 | 05:02 PM
Bwin's Avatar
Bwin
How do i remove the fake wood finisher off of all the interior of the car, so it can be washi aluminum.
Old Oct 1, 2009 | 05:44 PM
Ivoidwarranties's Avatar
Ivoidwarranties
Maybe this will get you started.
https://www.myg37.com/forums/d-i-y-i...ower-dash.html
https://www.myg37.com/forums/d-i-y-i...oor-panel.html
Old Oct 1, 2009 | 07:19 PM
HamstersG's Avatar
HamstersG
I'm curious. Can the wood be removed from the trim piece leaving Washi trim color under it? Or do you have to replace all the pieces with new ones?
Old Oct 1, 2009 | 08:55 PM
Mike P's Avatar
Mike P
No. You either have washi or wood. Only way is if someone stuck the wood aftermarket kit on it. You would have to take the wood out and replace with washi or vise versa.
Old Oct 1, 2009 | 09:26 PM
HamstersG's Avatar
HamstersG
Once you have the new pieces to install, there are other DIY for the dash pieces on the forum somewhere.
Old Oct 1, 2009 | 09:51 PM
Bwin's Avatar
Bwin
Ivoidwarrenties, that has nothing to do with what i need but thanks..
It looks like i could just peel the fake wood finish off... and some parts have the washi aluminum under it.
Old Oct 1, 2009 | 10:00 PM
HamstersG's Avatar
HamstersG
So you know that you have an aftermarket wood overlay?
Old Oct 1, 2009 | 10:03 PM
Bwin's Avatar
Bwin
The car was brand new when i bought it... right off the lot...
Old Oct 1, 2009 | 10:11 PM
HamstersG's Avatar
HamstersG
So is Wood Trim listed as an option on the sticker as coming from the factory? If you can peel it off and see washi trim, then what help do you need? Dealers can also add aftermarket wood overlays. You need to be more specific in what you what want help with.
Old Oct 1, 2009 | 10:12 PM
Mike P's Avatar
Mike P
If the dealer installed it, they should be responsible. Regardless of where you bought the car, you have the aftermarket wood kit. You will need a good adhesive remover but it should come off and the washi will show.
Old Mar 1, 2010 | 05:02 PM
ak47's Avatar
ak47
heads up the wood that comes from infiniti is 100% real trying chipping it alittle bit. its real...
Old Mar 5, 2010 | 04:05 PM
mark55's Avatar
mark55
do you have a sedan? if you have the real wood trim I'll trade you. i'm in nj
Old Mar 5, 2010 | 06:02 PM
JohnEnglish's Avatar
JohnEnglish
Yeah it sounds like the dealer stuck on one of those fake after market kits.
Old Mar 15, 2010 | 12:10 AM
ak47's Avatar
ak47
nah solid wood pieces from the dealer.
peterso2
Mar 25, 2019 11:28 AM
VIVID
Sep 26, 2015 02:02 AM
JerseyG
Sep 23, 2015 02:20 AM
philttz
Sep 21, 2015 11:12 AM
flyng_fool
Sep 17, 2015 08:58 AM
