DIY: Removing Front Grille
Old Feb 8, 2016 | 06:39 PM
  #166
SabanBec's Avatar
SabanBec
Thank you for the DIY, def will be swapping for the midnight grill soon
Old Mar 30, 2016 | 09:03 PM
  #167
Mick Brown's Avatar
Mick Brown
A great DIY is always helpful- looking forward to doing the grille swap as soon as weather permits.
Thanks very much.
Old Apr 11, 2017 | 01:31 PM
  #168
abbysG's Avatar
abbysG
I cant see pics anywhere? help?
Old Aug 20, 2017 | 01:47 PM
  #169
jrogue's Avatar
jrogue
Pictures:
https://www.myg37.com/forums/d-i-y-i...ml#post3967667
Thanks for the info... did not crack the cover thanks to you guys!
All the info covers the 'gotchas'... awesomeness! only took 20 mins to remove... and I took my time to be safe.
Much thanks again all!
Old Aug 21, 2017 | 08:36 AM
  #170
Landshark's Avatar
Landshark
after you remove the plastic rad cover, file the two holes that fit over the "prongs" to enlarge them a little bit.
easier to enlarge the holes in the plastic than it is to grind down the metal prongs.
now its easy to remove the 2nd time.
Old Jun 15, 2020 | 09:56 AM
  #171
kmeezy's Avatar
kmeezy
Years later and I needed this, thank you!
Old Nov 10, 2024 | 05:46 PM
  #172
09G37Coupe's Avatar
09G37Coupe
Thanks to the OP, and all the others that contributed to this DIY. I'm glad I read the entire thread before taking this on this week. No cracks on
my radiator cover, and I got the ugly grille with the peeling chrome swapped out. Look at the difference!
Thedbarz
33
Feb 9, 2016 12:05 AM
MJ HINX
Aug 23, 2015 10:30 PM
xpcgamer
Intake and Exhaust
Aug 4, 2015 02:18 PM
