HELP Removing BBK
Old Mar 14, 2009 | 06:03 PM
Wicked_limitz's Avatar
Wicked_limitz
HELP Removing BBK
Hey can anyone make a DIY for removing the oem BBK? Thanks
Old Mar 14, 2009 | 06:06 PM
Retromoe's Avatar
Retromoe
Is removing the BBK any different than changing standard brakes? Other than dropping it down or damaging its finsh.
Old Mar 14, 2009 | 06:37 PM
Wicked_limitz
i dont know, just trying to see if anyone can make a simple/easy diy so i know i wont fukc anything up lol
Old May 5, 2009 | 09:31 AM
twin001's Avatar
twin001
It's actually rather easy. Jack the car up and remove the tires. Remove the two 22mm bolts behind the front calipers and two 17mm bolts behind the rear calipers. If you are taking the calipers off them remove the 14mm bolt that attaches the brake line to the caliper and cap the line. Get a rubber mallett and hit the rotor until it breaks loose. That's about it.
Old May 5, 2009 | 09:58 AM
NJlakeshoreG's Avatar
NJlakeshoreG
when doing the rear, make sure the ebrake is off thats a handy FYI believe me, lol
Old May 5, 2009 | 10:03 AM
twin001's Avatar
twin001
^^agreed!
The rear rotors are always more difficult to remove. It took me a good 15 minutes of banging away at each rotor to get them broken loose.
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
ck1109
Oct 15, 2015 11:06 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 27, 2015 09:45 AM
