DIY: Headlight and Foglight Adjustment
Old Feb 5, 2019 | 11:15 PM
  #121
Marckly Charles's Avatar
Marckly Charles
Originally Posted by JT2014
Dumb question I did not see answered in 8 pages......
Which way adjusts up & which way adjusts down for the gear?
Thanks
This is the real question here lol all I was looking for the entire time for both headlights specifically
Old Feb 25, 2019 | 12:40 AM
  #122
Infinibini's Avatar
Infinibini
I lowered my car (now the front is lower than the back) and drove at night for the first time just now, and noticed the lights were pointing down. I'll have to adjust my lights.
Old Oct 9, 2019 | 03:10 PM
  #123
vqruby's Avatar
vqruby
hell yeah thanks for this
Old Feb 4, 2020 | 02:03 AM
  #124
JobbyKobe's Avatar
JobbyKobe
Does anyone know the part number or where to find more of the circled clips ?
Originally Posted by Jsolo
Been meaning to do this for a while now.
We're finally getting some warm temps so I figured do it today.
In the later models (mine is a 2012 sedan), the core support arrangement is similar, but different - also, the lamps are different too because the fog lights are now part of the lower bumper, not part of the main lamp assembly.
With a good flashlight, I was able to locate the adjusting holes and used a make shift screwdriver (several 1/4" extensions + philips bit) to reach down in there. It does take quite a few rotations to get any noticeable movement. I just used my garage wall as a reference and raised both sides slightly. Will drive tonight to confirm if it's good or if I need to raise/lower more.
My question is this; those plastic rivets holding down the weather stripping would just not release. Ended up breaking both on one side. Later realized they don't really need to come off to gain access.
Where do I get these replacement rivets without paying an arm and a leg?
part number or info on where to find the circled clips please?
Old Dec 31, 2025 | 12:48 AM
  #125
AMP_01's Avatar
AMP_01
Originally Posted by JSolo
Circled in red.
(in reference to post #91) What is the 1990s/2000s beige white thing by the big letter B circled in white? Everything I've found is that you use that to adjust your headlights on a. 2011+ G sedan? If you snap the white part off with pliers it shows an 8mm nut. Should I have never touched this when trying to adjust my headlight and getting frustrated at 0 results?
Drive Clean
Oct 9, 2019 03:08 PM
Steve 21
Aug 9, 2017 11:14 AM
slotterjordan
Jun 21, 2015 05:31 PM
dizismemo
Feb 3, 2011 10:53 PM
jo_sand
Car Care & Detailing
Oct 18, 2010 04:38 PM
