DIY: Easy Way to Reset ECU without battery disconnect
Old Apr 26, 2009 | 04:50 PM
  #76
333 4 ME's Avatar
333 4 ME
Not sure if this has been addressed already, but does reseting the ECU using this method clear the TPMS warning light after new wheels have been installed?
Dealer wants $30 to reset, and I am hoping I can get around giving the stealership more cash. If not, would a Cobb AP be able to clear the TPMS warning?
Old Apr 28, 2009 | 02:48 PM
  #77
SilverRSXJezus's Avatar
SilverRSXJezus
Originally Posted by kingsfan12
hey all, dumb question, but wat does reseting ur ECU do? can someone message me to let me knw
It lets the ECU take advantage of the extra ambient air coming in if you have an intake air scoop.
Old Apr 28, 2009 | 02:58 PM
  #78
ucla bruin's Avatar
ucla bruin
I know this isn't the place for it, but kingsfan, you might be running lean, which is potentially bad for the engine. Your ECU does adjust but only to a certain extend. If you ram the intake with too much air that falls outside of the ECU adjustment parameters, you will run lean.
You talked about your friend who is the guru on modding cars and ECU management, ask him if he knows about VVEL's different fuel trim and ask him to explain that to you. If he doesn't, I'd remove those scoops before they do damage to your engine.
__________________
Old Apr 29, 2009 | 05:05 PM
  #79
hispeed-lowdrag's Avatar
hispeed-lowdrag
diamond (or anyone) any video for this procedure yet? the timing is SOOO sensitive...
Old Apr 29, 2009 | 05:28 PM
  #80
Csquared's Avatar
Csquared
Use a stop watch, i just use the timer from my cd player.
Old Jul 23, 2009 | 08:29 PM
  #81
G37MA's Avatar
G37MA
Has anyone dine this on an 09 coupex. I'm having a lot of trouble!
Old Jul 24, 2009 | 01:42 PM
  #82
G37MA's Avatar
G37MA
BUMP - I have tried this a number of times on a brand new car with about 1100 miles. Hoping to get this done after the break in
Old Jul 25, 2009 | 11:30 AM
  #83
DetroitG37Joe's Avatar
DetroitG37Joe
If you have gotten TSB's such as the VVEL one and/or the station presets issue, etc. - this soft reset doesn't erase that or anything does it??
Old Jul 25, 2009 | 11:53 AM
  #84
G37MA's Avatar
G37MA
By the way i've done this numerous times on my S so I wasn't sure if it was somethignelse
Old Jul 30, 2009 | 02:07 PM
  #85
Sharp_cai's Avatar
Sharp_cai
Is that posssible dont reset the ECU after put intakes and exthaust on the car? Will it still learn it by itself?
Old Aug 26, 2009 | 06:37 PM
  #86
TheDuke's Avatar
TheDuke
Originally Posted by SchoonerVanHlmt
I downloaded the G37 Technical Manual last year, as this is how you reset the ECU. I have tried several times as well, just comes down to getting your timing correct. Hope this helps
I just did it this way and I think it worked. The SES light flashed fast after the 20 sec and went off. BTW, this is different than the original post said to do, this says to hold the petal down for 20 sec, not 10 and then 10 again?
Old Dec 1, 2009 | 02:42 PM
  #87
beast808's Avatar
beast808
this is so hard i tried like 100 times and still never got it
Old Dec 1, 2009 | 02:47 PM
  #88
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
I got it on my first try dude. Its pretty straight froward
Old Dec 1, 2009 | 07:51 PM
  #89
ucla bruin's Avatar
ucla bruin
Did you try it with my timing? It works fine on my car. But when I just recently did it for someone else, I actually had to change the timing a little bit to get the CEL faster.
__________________
Old Dec 2, 2009 | 02:07 AM
  #90
beast808's Avatar
beast808
i got it but only the service engine soon light began to blink is that suppose to happen?
