Fuel Door rubbing against fender
Hey Guys,
I have a 2013 G37 Sedan and I'm wondering if anyone has this problem...
When I open up the fuel door, the right side of the fuel door (the side on the hinge) rubs against the inside of the car. Not only does it make that rubbing noise, but it's actually rubbed off the paint on the inside fender area.
Put in other words, it's almost like the fuel door is not centered correctly, like the fuel door is sitting slightly too much to the right, so when you open up the fuel door it rubs against up against the inside of the fender.
Has anyone else had this experience?
Can this be fixed?
Thanks!
Can this be fixed?
Thanks!
Last edited by TURNandBURN13; Nov 18, 2013 at 12:37 PM. Reason: added the word "sedan" to clarify the model i own
my car doesnt do this but the loaner i had for a few days did. there are two torx head screw inside the fuel door area, you can probly adjust the door loosening and re-tightening them. i think they are on there quite tight.
FlyIce
Sep 29, 2015 04:07 AM
Murkr
Sep 28, 2015 10:45 AM
