Simonise(sp?) leaving foggy look
Old May 14, 2009 | 06:17 PM
SaMaster14's Avatar
SaMaster14
Well... when I was taking the "G37" decals off my car, I used simonise(the stuff that is used to remove small scratch stains and stuff), and after, a foggy imprint was left where I rubbed the simonise. My dad has used the same stuff on his car and it left the foggy stuff, but it went away after time(I think). Will this foggy look go away if I just leave it?
Sadly, I'm not by my car and can't get a picture at the moment, but I will soon.
Old May 14, 2009 | 07:18 PM
SaMaster14's Avatar
SaMaster14
Here is a picture of the foggy part i'm talking about for better clarification:
Old May 14, 2009 | 07:20 PM
aliiin's Avatar
aliiin
BMW Defector
how did you use the simonise? when i debadged the "sewell" off my car, i used floss, a hair dryer, and goo gone to remove the residue. have you tried clay barring the area?
Old May 14, 2009 | 07:23 PM
SaMaster14's Avatar
SaMaster14
What is clay barring?
And, all i did was use floss the get the badges off, and than got the glue off pretty easily by rubbing it, and using the simonise. All i did was put some on a clean cloth(and a car-friendly cloth), and carefully wiped. My dad used the same method on his car, and the same foggy stuff came up, but now I haven't noticed the fog on his car, so i'm hoping it will just go away after time on my car, like it did on his.
Old May 14, 2009 | 09:40 PM
gtracing's Avatar
gtracing
you might wanna use some sort of clear coat cleaner and see if that fog will come off...or else if you want it off a quicker way, clay bar (that's if it's only a surface stain and not actually caked into ur clear coat) or cut/polish...
Old May 14, 2009 | 10:41 PM
vINCe_Inc's Avatar
vINCe_Inc
looks like you 'waxed' the car with residual glue.
Old May 14, 2009 | 10:54 PM
PSYH's Avatar
PSYH
Post Whore
You used Simoniz what? Simoniz is a brand name, not a product name.
If you're lucky, it's just residual glue that's smudged all over. Google what a clay bar is and then use it.
Old May 14, 2009 | 11:32 PM
SaMaster14's Avatar
SaMaster14
It says a clay bar is similar to a heavy rubbing compound... The simonise stuff I used is called a heavy rubbing compound, and that is what put it there in the first place.....
EDIT: I looked at the stuff I used, and its not called simonise, its just called Heavy Rubbing Compound(my dad just calls it simonise).
But that rubbing compound is what put the foggy look there in the first place....
Old May 14, 2009 | 11:39 PM
EnviedG35's Avatar
EnviedG35
Ive always used Goo Gone to clean up glue residue after debading. Works wonders. Just put some wax on after its all cleaned up.
Old May 15, 2009 | 09:05 AM
KLB's Avatar
KLB
You should research before you put anything on your car. A rubbing compound is basically a very fine non-solid sand paper.
I would guess you will need to actually polish it now to remove that, but one of the more experienced members here can point you in the right direction.
Not sure how your dad's went away, unless the clearcoat "healed" itself.
Old May 15, 2009 | 11:21 AM
SaMaster14's Avatar
SaMaster14
My dad told me to use it. And I was recommended to be used for what I did.
Its not like I blindly did it. U used it for what it should be used for.
If the foggy stain doesn't go away soon, ill take it somewhere to be fixed.
Old May 15, 2009 | 11:25 AM
oOmikeyboy's Avatar
oOmikeyboy
For the rest of the stuff that you plan to take off:
1. hairdryer to heat up the glue (dont stay in 1 spot too long)
2. fishing line or dental floss to unstick the badging
3. goo gone to remove the leftover glue
4. scratch-x 2.0 for the little scratches you probably put in the car, and then wax.
I did it for the entire trunk lid of my car, and it came out just fine.
for the problem of the hazing, foggy look..is there scratches?
Old May 15, 2009 | 01:07 PM
lmulion03's Avatar
lmulion03
It seems as though it needs to be polished - just like when you use sandpaper - need to polish it off.
Old May 15, 2009 | 01:10 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
The stuff you used has ETOH in it which will cause a foggy look upon using it on paint. PM me and I'll help you out since we are local.
Old May 15, 2009 | 10:26 PM
SaMaster14's Avatar
SaMaster14
Its actually coming off after time, little by little. And, i'm gonna go out and get some goo gone this weekend.
And, for the rest of the stuff, my dad is taking me and my car when he gets his MBZ done, since he needs work on it too.
User 122320
Oct 19, 2016 05:13 PM
tomro99
Nov 17, 2015 02:08 AM
Slapshot1
Sep 27, 2015 08:40 AM
JakeG37
12
Sep 24, 2015 01:03 AM
