View Poll Results: What should i do before winter.
Paste wax
11.76%
Clay bar and wax
58.82%
Get it done from local detail shop
29.41%
Voters: 17. You may not vote on this poll
Help Before the winter hits..
Old Nov 7, 2008 | 03:21 AM
J.Oh's Avatar
J.Oh
go to andrews. have him do a full exterior with jetseal.... freaking noob
Old Nov 12, 2008 | 11:53 AM
Heat's Avatar
Heat
Definitely clay bar and full detail. It will help keep the dust off of it. You will have plenty of time while it sits in your garage.
Old Nov 12, 2008 | 01:14 PM
Seer's Avatar
Seer
Clay bar, wax, sealants etc will not repel the dust, if it is sitting uncovered all winter.
Only way to keep dust off the car is to keep it covered. But make sure to do a good detail before hand, keep the surface slick for the cover to sit on it.
Old Nov 12, 2008 | 03:26 PM
SpecC's Avatar
SpecC
washing, claying, putting sealant and wax on isn't that hard... is this comment really necessary?
Old Nov 12, 2008 | 04:14 PM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
Did you just quoted "homelessdrunk"?!!! I feel sorry for you. That was a mistake.
Old Nov 12, 2008 | 05:49 PM
Heat's Avatar
Heat
Why must I have to always explain myself. Cant you read between the lines. The point was that just clay bar and wax will not keep your car clean all winter long. Full detail means clay bar, polish, sealant, gloss or wax. And yes, their are products out there that will HELP repel dust, as I said.
On a side note, if you are going to cover it, don't buy a cheap car cover. They only make it worse and trap dirt and dust.
Old Nov 12, 2008 | 06:35 PM
Seer's Avatar
Seer
i wasnt talking to you, so no need to explain yourself.
Old Nov 12, 2008 | 07:25 PM
SpecC's Avatar
SpecC
a car cover scratches every time you put it on and take it off unless you have the dexterity of a surgeon every time
Old Nov 12, 2008 | 07:36 PM
Seer's Avatar
Seer
I have one that has a premium microfiber lining... no scratches
Old Nov 13, 2008 | 07:06 AM
Garnet Canuck's Avatar
Garnet Canuck
Traveling Administrator
Originally Posted by tfongg37
Hey I did a clay bar and 2 coats of wax,
can i still use a sealant, then wax again???
No, you won't be able to apply a sealant over a wax as it won't adhere properly. You will need to strip your current wax before you apply the sealant. Once you apply the sealant you'll then be able to apply your favorite carnuba.
Old Nov 13, 2008 | 09:53 AM
Heat's Avatar
Heat
^^What he said.
indyn
Nov 17, 2015 06:48 PM
Dillybar12
Nov 1, 2015 07:23 PM
ck1109
Oct 15, 2015 11:06 PM
rk325
Oct 13, 2015 01:51 PM
bobtaz13
Oct 1, 2015 01:39 PM
