My Mod + Dyno Log
I recently heard about beluga racing. I talked to them when I was considering their resonated test pipes. Their service is pretty good and comes with 1 year warranty, so their headers might be an option for me in the future.
What I don't know now is if I should keep the MXP RTPs or go back to the FI RHFCs now that they are fixed.
Today was a bad dyno day. Maybe the dyno was off or idk but didn't really gain anything. Went from 301 to 298 with no improvement anywhere in the graph. I'll post the picture of results tomorrow.
I'm not too sure, but I don't really think the RHFCs are to blame. Here is the graph. The new mods from the last run where NST pulleys + lightweight wheels and tires.
Sorry I had the colors reversed I guess.... This is beyond my car smarts sorryy, wish I could help. I asked my friend that works at D3 in Houston as a tuner, he said there's a ton of reasons it could happen, and that our motor doesn't respond too well to n/a mods so they don't work with n/a VQ's. He didnt elaborate beyond that.
I guess the heavier rotating mass helps in a sense that it will help the engine speed up and keep the crank spinning faster. Kind of like a rock at the end of a string, once you start spinning the rock the end result will be the rocks momentum will keep the speed while your arm does minimal work. So I guess heavier pulley's is a good thing. To a limit.
temperature atmosphere playing a factor. couldnt tell the temp but there is a change in humidity. and of course you gonna have to retune for the pulleys. loss of 3 horses is not sumn to die over.
I wouldnt say you lost power, 3hp is negligible. Just not worth it. Damn you literally made the runs at the same time at different days.
