My Mod + Dyno Log
Old Dec 11, 2014 | 10:47 PM
  #346
Originally Posted by alfredo24pr
Thanks.
I'll still be doing before and after dyno runs for all the future mods.
Looking forward to the results and sorry about your issues w/ the HFCs, I know you'll get them back where they need to be.
Old Dec 11, 2014 | 11:46 PM
  #347
alfredo24pr's Avatar
alfredo24pr
I just hope I'll be happier with the MXPs. That way I won't miss my RHFCs much.
Old Dec 13, 2014 | 11:15 AM
  #348
G37Genova's Avatar
G37Genova
Alfredo does the NST pulleys come with a new belt? or do you reuse the old belt? The reason Im asking is because the dealorship said my belt was cracking and wanted to charge $270 for it id rather pay $248 for the pulley system if it comes with a new belt
Old Dec 13, 2014 | 12:46 PM
  #349
alfredo24pr
No, the belt does not come with the pulleys. Also, it is a slightly smaller belt for better fitment with the new pulleys. Link of the belt below:
Amazon.com: Gates K070786 V-Belt: Automotive Amazon.com: Gates K070786 V-Belt: Automotive
Installation of the pulleys is around ~$200.
Btw, NST has horrible service so if you order the pulleys from them, your old belt will probably break and you would still be waiting for NST to ship your pulleys lol (srs)
I waited 2 months for these and they shipped them after I filed a report to my bank. They always say their pulleys are in stock and ready for immediate shipping. Clearly, they are not.
Oh and just this week I found a company that sells this same set but stock size (not underdriven). Link below for those interested.
GarageLine 2009-13 Nissan G37 Lightweight Crank & Alternator Pulley - Welcome to GarageLine - Sport Compact Performance Parts
Old Dec 14, 2014 | 01:10 PM
  #350
G37Genova's Avatar
G37Genova
The garageline pulley is interesting. Do you know about there customer service at all? I have to do a good search and figure this out. Also is the pulleysthe same size so id use an oem belt?
Old Dec 14, 2014 | 02:12 PM
  #351
alfredo24pr
I would guess that you would still use the OEM belt.
About their customer service, well idk, but they do post on the370z forum.
GarageLine Prototype Pulley Review - Nissan 370Z Forum
Old Dec 15, 2014 | 03:27 AM
  #352
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
What do you plan on doing with your RHFC?
Old Dec 15, 2014 | 12:19 PM
  #353
alfredo24pr
I'm sending them over to Fast Intentions as soon as I get my MXPs installed, to see if they can be fixed.
If I'm ok with the MXP double resonated test pipes, then I will probably sell them afterwards.
Old Dec 19, 2014 | 03:02 PM
  #354
Alfredo, my mechanic is planning on re-using this bracket with some custom welding for the matching hangers.
Well, I suppose that would work even better. Please try to take some pics when you get this done. I might also do it then.
A small block of metal, like the size of a domino, was very securely welded to the mid-pipe section of each RHFC, with two holes drilled through each. On the other side of each hole, a nut was welded on for the threads (and to eliminate the need for a crescent wrench in tight spaces.)
The OEM support beam had the 1" turned-up ends cut off, and a length of L-shaped metal was then welded to the OEM support piece, turning it into a large D-shape, if you can visualize that.
The whole thing bolts right back up where it was originally mounted, using the two OEM bolts with bushings, and two new bolts on each corner into the customized section.
Then all the edges were trimmed up, and everything was painted. I have to say, it looks extraordinarily OEM at first glance. It's really a superior, creative piece of work.
As for changes... there is ZERO vibration now from the exhaust! I'm rather shocked about that. So that's a huge win... that and the confidence in knowing I may have headed off a cat-failure down the road.
Thanks, Alfredo!
Old Dec 19, 2014 | 04:46 PM
  #355
alfredo24pr
Thanks, Alfredo!
Looks like I took one for the team lol.
I was also surprised how the vibration was reduced after my muffler shop welded some extra hangers.
Anyway, that work looks pretty darn good.
Might steal that idea
Old Dec 24, 2014 | 12:16 PM
  #356
alfredo24pr
Finally arrived!
If everything goes right, these will be installed by this afternoon, along with the NST pulleys.
Old Dec 24, 2014 | 12:26 PM
  #357
Adjustable length hangers, that can be bent to fit. And O2 connectors welded as a two-piece, 45* angle. I swear, it almost looks like those O2 sensor connectors are designed to swivel to however you need the sensors to hang... is that right? Amazing.
That is so-o-o cool looking. Very impressive piece of mechanical work.
Old Dec 24, 2014 | 02:56 PM
  #358
alfredo24pr
Adjustable length hangers, that can be bent to fit. And O2 connectors welded as a two-piece, 45* angle. I swear, it almost looks like those O2 sensor connectors are designed to swivel to however you need the sensors to hang... is that right? Amazing. That is so-o-o cool looking. Very impressive piece of mechanical work.
You lost me lol. Hopefully, these pics will answer your questions.
NST pulleys were not installed
Will have to wait until January.
Old Dec 24, 2014 | 04:54 PM
  #359
GW330's Avatar
GW330
How does it sound? Hows the difference in exhaust odor? They look great!
Old Dec 24, 2014 | 05:35 PM
  #360
alfredo24pr
Haven't noticed odor for now and I was checking for it. The loudness is a bit more, but sounds very good. More exotic and a bit less deep.
Only negative is that it has more drone than the FI RHFC when accelerating on a high gear in highway.
