My RB Project, going all in!
looks easy enough...haha wow i really hope this works out, good luck!
do you think, after everything, you will be below the dollar figure of those curiously priced FI kits for the g? or is it more of a uniqueness factor that's driving you?
Plans for the car once done? Any track time?
Thanks man, yeah I make it seem too easy but the guys there are working on my car full time. They're very competent
I read somewhere the difference between a VQ35 and an RB block is around 200 lbs. If you compare a VQ37 block with an A/T vs an RB engine with an M/T I think the gap gets narrowed down. Either ways, adjustable coils and a front strut bar are on their way to fine tune the suspension
I don't want to get too ahead of myself yet, let's see how it plays out. The challenge is to make this a DD for a while until I get my hands on a beater later on.
Regardless, mad props for trying this. I'm really impressed and pleased to see some true modding going on in one of our cars!
Cool. Yeah, I was just curious if the RB would make the car more balanced or less. I'm guessing less since it's a longer block (granted an assumption given I6 vs V6). And yes, coilovers will do the trick for setting the right stance and weight balance to an extent. Was just secretly hoping the RB would help with front end push
Regardless, map props for trying this. I'm really impressed and pleased to see some true modding going on in one of our cars!
i kept skipping over this thread for a week or 2 now like eh i'll look at it later and never really got around to it until now, and i wish i looked sooner, this is incredible. i am definitely sub'd to this, and cannot wait to see the finished product. hats off to you for doing this man!
Thanks for the kind words
I just got word that the engine mounts are almost ready and the transmission spacer is being fabricated as I type. I'm getting very excited and impatient now haha
I've wondered about this for a long time since I've not yet built an engine with a standalone ECU- does the new ECU talk to the factory idiot lights on the dash? How about the information screens? I guess I'm wondering how much integration can actually be achieved with a standalone vs a reprogrammed stock ECU (like Osiris or similar)?
Obviously since you're running a completely different block, and mechanical throttle to boot you can't simple reprogram... I have just been thinking about how something like this would behave on a DD.
Update 10-12-2012:
Great news! The shop is done with the engine and transmission alignment and I couldn't be happier. The shifter now sits 100% OEM and the best part, I won't even have to modify my center console for it.
Shifter in Neutral
Shifter in Third
Shifter in Reverse! Look at that clearance!
Shifter in Fourth
Engine mounts have been spot welded today, everything is looking perfect. Tomorrow they'll get welded and finished to look 100% OEM
The Transmission spacer is also ready, 26mm thickness
Here it is with the OEM flywheel for your reference
Turbo fitment is still tight especially on the turbine side. That line will have to be relocated for sure.
And finally, the finalized engine position. Gotta love that RB tilt!
Shifter in Neutral
Shifter in Third
Shifter in Fourth
