Black Pearl Worklog
Old Sep 11, 2015 | 09:59 AM
  #241
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Trans is still holding strong. Some track time down and hard 0-120 pulls, zero hiccups.
Old Sep 11, 2015 | 09:09 PM
  #242
Great news! Were you running the drag strip or a road course?
Old Sep 14, 2015 | 09:08 AM
  #243
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Road course for a day and some 1/4 drag strip time too!
Old Sep 14, 2015 | 09:12 AM
  #244
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Couple of drag strip pulls.
Old Sep 14, 2015 | 09:58 AM
  #245
ttv36's Avatar
ttv36
Race, repair, repeat.
I hate you and your fancy AWD! Hopefully I can get out to the track again soon.
Old Sep 14, 2015 | 02:52 PM
  #246
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Haha, Tony, you'd still kill me on a roll. I'm going to try to run the NT01 setup next and see if that helps times a bit.
Old Sep 15, 2015 | 06:13 PM
  #247
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by Lt8Che
I can give a quick write up.
Firstly the Bosch Module (Traction Control/Yaw Sensor) is located right behind our shift units, it sits underneath the cup holders. The easiest way to get to it is to take off the front of the arm rest storage (the part with the USB and 12v charge)
When you get that off you can see the Module with a black plug and four wires coming out of it. The wires are green, light blue, yellow, and black. The green wire is the power source.
I cut this wire and spliced a switch into it in order to have a way to completely shut of the Traction Control and associated electronic assistance.
I took some pictures and will post them up when I find them.
Just did a quick write up to help out
https://www.myg37.com/forums/d-i-y-i...ml#post3939606
Perfect! Thanks so much for putting this together. Seems pretty straight forward, but this will definitely simplify the process. I even have an extra blank switch plate between my seat heater switches that I can use for the switch.
Thanks for keeping us all up-to-date on your tranny. I haven't pulled the trigger on the Level 10 tranny yet, but it's my next major modification. After that there's not much left to do.
Old Sep 16, 2015 | 09:34 AM
  #248
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
No prob. I'm trying to keep everything up to date so it helps others out. If people can avoid some of the headaches I've had it makes it worth the post!
Level 10 is definitely the best bang for the buck for our 7AT's! I highly suggest them.
Old Sep 24, 2015 | 06:51 PM
  #249
2GoRNot2G's Avatar
2GoRNot2G
Mine's actually a 5AT, but I don't think that really changes anything regarding Level 10... I've talked to several people with fully build 5AT from Level 10 and all are very happy. I'll probably plan on doing that project over the holidays this year when I don't plan to drive the car much. Will definitely let you know how it works out!
Old Sep 25, 2015 | 08:37 AM
  #250
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
The current 1/4 mile record is set by a Jim Cooper (SharpbyCoop) on the forum. He had a 5AT built by Level 10, so you would be in good hands. His engine failed before his transmission showed any hiccups.
Old Oct 4, 2015 | 05:33 PM
  #251
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Having some fun at San Antonio Raceway!
Old Oct 4, 2015 | 05:45 PM
  #252
PongSanity's Avatar
PongSanity
Power! Let's see those slips! Gears so short, 5th gear was necessary. Sounding good man. Real good....
Old Oct 4, 2015 | 07:35 PM
  #253
Redfire32's Avatar
Redfire32
Ginger ninja
Man you've got your car running at superman levels!!! Nice work.
Old Oct 4, 2015 | 10:20 PM
  #254
PongSanity's Avatar
PongSanity
Black Pearl Worklog
What's your tire setup? I think it's Volk rims you got.
Old Oct 4, 2015 | 10:24 PM
  #255
PongSanity's Avatar
PongSanity
Thanks! The TE37sl's are awesome. The fitment is pretty spot on, not as perfect as my F14 setup but really close, the 275 NT01's help it out. It's a good track setup for sure and looks great too!
Got my answer lol.... research helps.... I'm on 275 nt05s.... looking at the nt01 or Toyo r888 on enkei rpf1 as my drag setup....
