Alignment Question , Winter / Summer tires
Hi Guys,
Hope everyone is doing well, i took a pothole a couple of months ago and dented my vossen rim, then had the rim refinished and re-balanced, everything seemed good, then when it came for winter time i removed my vossens and lord be hold i saw that my front right tire was really worn out from the inside side.
Now heres the issue i changed to my winter tires because well it start snowing, but i have 18's installed with spacers because my rims the stock OEM G37 18's wont clear so i had no choice but to use spacers.
My question is can i get an alignment with my winter setup "18's on spacer" and will that alignment be valid for my Vossen 20's also ?
i'm getting new 20's Falken FK453's for the summer and really dont want to wear them out because of a messed up alignment
Also note , my steering is perfect center LOL otherwise i would have done the alignment in the summer.
My G37x is stock height and yes i install the BBK after purchasing it
Sorry for the long post
