Stiff Steering after after run off the road
Old Sep 17, 2019 | 02:10 PM
G-manForLife's Avatar
G-manForLife
Ok guys I have a 2010 G37 with stiff steering. I just picked it up from the dealer and they couldn’t find nothing wrong with the power steering or the rack. It did not start this until I was ran off the road by a 18 wheeler. Can you guys please give me insight on what to look at because this is not normal and it seems the dealer can’t help me either
Old Sep 17, 2019 | 05:15 PM
2011-G's Avatar
2011-G
You might want to check your front sway bar - It might have bent
Old Sep 18, 2019 | 01:10 PM
Conboss's Avatar
Conboss
Glad to hear your ok! Is the steering still straight?
Old Sep 18, 2019 | 01:35 PM
Surfnazi's Avatar
Surfnazi
Did you check atf fluid in ps reservoir
Old Sep 18, 2019 | 02:41 PM
G-manForLife
Yes the fluid filled to the max line and the dealer did an alignment for me
Old Sep 18, 2019 | 02:47 PM
Surfnazi's Avatar
Surfnazi
Does your steering from lock to lock feel like its binding if so pump could be going out
Old Sep 19, 2019 | 11:01 AM
G-manForLife
No it doesn’t feel like it’s binding but does get softer when the wheels start moving
Old Sep 19, 2019 | 03:35 PM
Conboss's Avatar
Conboss
Thats normal, if you take a wheel and try to rotate it on the Y axis, its not easy. If you rolled the wheel and tried to turn it the exact same way it will go easier due to lower friction.
Old Sep 21, 2019 | 08:23 PM
Surfnazi's Avatar
Surfnazi
You might have damaged your steering rack mine was when I got run off into grass
kroy
Oct 21, 2017 09:39 PM
mauiwowie
Aug 16, 2015 06:01 PM
ScorpionG37S
Feb 11, 2015 11:32 AM
G37slove100
Oct 18, 2013 02:37 PM
