Cambie Kit V36 sedan with swift springs:
Old Jan 26, 2016 | 08:07 PM
Ricio1991's Avatar
Ricio1991
Hello all I have swift springs on my RWD sedan, at first I thought I could keep in oem specs with oem camber kit but today I stopped by dealer for some road noise and the tech advised me that my aligment was off and at first that nothing else was wrong and also said that the type of tire caused the noise, before putting tires Infiniti tech felt wheel bearing loose and decided to exchange it for me, before I brought it in I thought it was the bearing and explained to them, they told me the reason the bearing went bad is due to the mis aligment witch i did not believe because I got it aligned a week after spring install (5mo ago)!! Anyways they advise me to get camber kit so should I get rear camber arms only and all 4 toe bolts or front camber arms as well! Opinions needed
Old Jan 26, 2016 | 09:57 PM
Hard to say without seeing current alignment specs. Do you have your alignment spec sheet available?
A RWD on Swifts should be able to get reasonable wear w/ the rear 4 bolt set (2camber arms bolts, 2 toe bolts), you can get the front toe in spec no problem and should have front camber around -1.8 to -2, since the rear wears faster it's best to get that camber in the -1.2 range w/ toe in spec.
That 4 bolt set should get you back to a good place.
Old Jan 26, 2016 | 11:12 PM
Ricio1991's Avatar
Ricio1991
Thank you for all the info, tommorow I will going back to get an aligment where they do computer ones and see what they recommend and what specs they can get it to
Old Jan 26, 2016 | 11:36 PM
Ricio1991's Avatar
Ricio1991
This should do correct, for installation how much is it for normal labor and who can do it performance shop or aligment shop maybe? What's a reasonable price and do they need any specific tool for it?
Attached Thumbnails Cambie Kit V36 sedan with swift springs:-photo527.jpg
Old Jan 26, 2016 | 11:47 PM
Here's the SPC instructions
https://www.myg37.com/forums/brakes-...-template.html
This is something best done by a shop that's done it before or not too hard to DIY. Some shops that just deal primarily w/ bone stock cars can be clueless TBH.
Here's a post that may help
https://www.myg37.com/forums/build-t...ml#post3986266
As far as what A shop would charge, not sure, but it took me about 20 minutes to do the toe bolt slots, so I'd say about an hour of labor, whatever the going rate would be in your area.
Old Jan 26, 2016 | 11:50 PM
Ricio1991's Avatar
Ricio1991
Nice thanks!
Old Jan 27, 2016 | 04:26 PM
Ricio1991's Avatar
Ricio1991
Camber is fine, toe is what's out again, we're going to get it aligned to spec, will post the sheet after there done, I'm at around negative 1.7 in camber witch I'm not worried about but the toe is what I'll keep an eye on.
Old Jan 27, 2016 | 06:07 PM
Ricio1991's Avatar
Ricio1991
Here are the updates specs now
Attached Thumbnails Cambie Kit V36 sedan with swift springs:-photo292.jpg
Old Jan 27, 2016 | 08:56 PM
I think you can live w/ those alignment specs. I forget, do you have a square wheel setup or staggered? If you're running square just rotate a bit more often, like every 7k miles. If you have assymetric tires on a non staggered you can still rotate side to side to help out a bit.
Old Jan 27, 2016 | 09:26 PM
Ricio1991's Avatar
Ricio1991
Yes I have a square set up and I rotate every 6k miles actually recommended by discount tire, thanks again I'm sure my tire wear is fine the tech stated I have good tire thread
itengineer
Jan 1, 2016 11:15 AM
Baby Jumpman
Dec 30, 2015 03:01 PM
Silverbyte
Dec 3, 2015 11:29 AM
iCrap
Dec 2, 2015 08:58 PM
