Another Brake/Rotor Thread
Old Oct 6, 2015 | 11:10 AM
Victory's Avatar
Victory
Originally Posted by gmanny86
Thank blnewt and Victory! I'm about to place an order for StopTech Street Performance Brake Pads and Centric Premium rotors! Do any of you know if the disc brake hardware is included with the pads or do I have to purchase that separately? Thanks
I know other centric pads come with a hardware kit, but i dont know about the stoptech pads. A hardware kit shouldnt be more than $5-10, or you can reuse your old ones (hit them with a wire brush and brake cleaner then lubricate)
Old Oct 6, 2015 | 04:13 PM
The Stoptech pads (at least when I ordered them only came w/ the pads, no hardware kit or shims) the Posi Quiets DO have the hardware kit. Like Victory mentioned, should be able to reuse your set, and the Stoptech pads don't require any shims. If you want the hardware kit you only need one kit for the front and one for the rear.
Old Oct 6, 2015 | 06:17 PM
Victory's Avatar
Victory
Let me know how you like them. I'm waiting out whatever brakes were on the car when i bought it.
I'll suggest meguiar's wheel brightener. If the brake dust is particularly bad. Wear gloves and eye pro. It's powerful stuff.
Old Oct 7, 2015 | 10:21 AM
gmanny86's Avatar
gmanny86
Thanks for the info guys! Very much appreciated. I'll hopefully install them this weekend and I'll let you know how they are. I'm excited since this will be the first time changing brakes on my Infiniti!
Old Oct 7, 2015 | 01:08 PM
I'd be sure to do a full brake fluid flush too, rather than just a top-off. I've had good results w/ Valvoline Dot3-4 full synthetic and a quart jug will be plenty.
Old Oct 7, 2015 | 09:25 PM
slartibartfast's Avatar
slartibartfast
Ford Heavy Duty brake fluid is some good stuff, too. That's what we used in our LeMons Sentra SE-R road racer. One of the highest dry boiling points out there. Wet boiling point isn't class leader but it's as good as most other consumer brake fluids.
Old Oct 7, 2015 | 10:53 PM
Victory's Avatar
Victory
Where do you find that stuff nowadays? Haven't seen any in 10 years.
Old Oct 8, 2015 | 08:14 PM
slartibartfast
Four years ago at a Ford dealer. We used it in our LeMons Sentra SE-R. Haven't look for brake fluid since.
Old Oct 8, 2015 | 11:43 PM
Landshark's Avatar
Landshark
i had Hawk Performance Ceramic on a previous car, and they had good bite and far less dust than stock pads.
not sure if they make them for the G, but if they do, im going with them when its time ....
Old Oct 9, 2015 | 11:30 PM
2012G37's Avatar
2012G37
I'm not 100% sure, but I have possible front rotor warp with stop tech (slotted ). I'm pretty sure I will get new ones after warranty procedures. If it happens again I may look at other options.
Old Oct 9, 2015 | 11:53 PM
Victory's Avatar
Victory
Slotted rotors can cause noise and vibrations that can be mistaken for being warped. Another reason i prefer blanks.
Old Oct 10, 2015 | 09:11 AM
2012G37's Avatar
2012G37
Interesting, my shop is suppose to do some measurments on them and contact stop tech on Tuesday. I plan on doing a service at the dealer monday, I may ask them to look at it just incase the vibration is not related to the brakes.
Old Oct 12, 2015 | 12:45 PM
gmanny86's Avatar
gmanny86
So I installed my stoptech pads with my ceramic blank rotors on Friday night. The install was really simple. The brakes grip on really good and stopping is not a problem! I would recommend them 100%. Money well spent!
Old Oct 13, 2015 | 01:21 AM
  #29
Victory's Avatar
Victory
Great. Let me know how the dusting and noise is after you've had them a bit.
37
Oct 17, 2020 11:12 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
