Old May 31, 2016 | 06:44 PM
  #586
the93owner's Avatar
the93owner
Originally Posted by jfisher
Looks good! Any shots from above the fenders looking down onto the wheels?
Here you go. I didn't do any fender mods and they clear fine
Attached Thumbnails HELP~All squared setups please post here!-photo303.jpg   HELP~All squared setups please post here!-photo650.jpg
Old May 31, 2016 | 09:33 PM
  #587
jfisher's Avatar
jfisher
Just curious about the fitment. These cars don't really rub unless you get crazy tires. I've run 19x10.5's with +24 offset with no rubbing.
Old Jun 1, 2016 | 04:03 PM
  #588
dsolis's Avatar
dsolis
Brian Are you lowered?
Old Jun 1, 2016 | 06:55 PM
  #589
BrianG314's Avatar
BrianG314
No, stock height. May lower it in the future but I think it looks fine for now.
Old Jun 15, 2016 | 04:23 PM
  #590
Broski28's Avatar
Broski28
To the guys running 20x10.5+25 all around on coupes:
How much camber is needed in the front and back? I don't mind slightly out of spec but I am just trying to put it into perspective before I get new wheels.
Also is it possible to run a 265/30/20 tire instead of the fairly common 255/30? In doing so will I need to add slightly more camber?
Old Jun 15, 2016 | 04:37 PM
  #591
tbulsara's Avatar
tbulsara
i had -1 camber all around. i did however have my fenders rolled and pulled, front and back,
also, i was running 275/30/20 so running a 265 should be no problem..
Old Jun 16, 2016 | 11:10 AM
  #592
Broski28's Avatar
Broski28
If I didn't roll and pull do you think I could get away with say -2 camber and a 265?
I was hoping to not have to pull or roll and still run a semi wide tire.
Also do you have a coupe or sedan??
Old Jun 16, 2016 | 11:19 AM
  #593
Ape Factory's Avatar
Ape Factory
19x9.5 +33 on 245/40/19. Perfect fit all around!
https://www.instagram.com/p/BGCSizvR76J
That looks really good...
Old Jun 16, 2016 | 11:36 AM
  #594
tbulsara's Avatar
tbulsara
I have a sedan.. and yeah going -2 you should be fine...
Coupe can run more aggressive offsets.
Old Jun 17, 2016 | 04:21 PM
  #595
Broski28's Avatar
Broski28
Wow thats sharp man! Looks great.
Thank you for the help
Old Jun 23, 2016 | 09:55 PM
  #596
the93owner's Avatar
the93owner
Another shot of my setup, 19x9.5 +33 all around with no spacers or fender work. Hope it helps some of you
Old Jun 24, 2016 | 02:06 AM
  #597
Gregor12's Avatar
Gregor12
Soooo. What do you guys think?
Wheels: 19x9.5 +40
Suspension: Eibach prokit springs
Tires: 275/35 or 255/40??
Old Jun 24, 2016 | 02:07 AM
  #598
Gregor12's Avatar
Gregor12
So sexy. What size tire are you running?
Old Jun 24, 2016 | 08:52 AM
  #599
Wheels: 19x9.5 +40
I've got 9.5 +38 on 245s and IMO the 255s would fit well, I wouldn't go wider than 265s in front. A 255/275 stagger could also work on a RWD.
the93owner is running 245s
Old Jun 24, 2016 | 09:01 AM
  #600
the93owner's Avatar
the93owner
Wheels: 19x9.5 +40
I'm running 245/40, the stretch is minimal if any, and is the closest size to OEM. 275 may be a tough fit up front, but the size of the wheels themselves should fit no problem.
